? about prestone anti freeze.
Old Feb 8, 2006 | 11:03 AM
BLACK Z !'s Avatar
prestone antifreeze full strength, why is it so light, antifreeze used to be dark green this stuff is almost clear. I see they have the pre mix stuff almost every where, but I brought the full strength thinking it would be dark green.and then when you mix it 50/50 with it it gets real light. Is this stuff any good? can I mix it with other anti freeze? is it safe for aluminum? what are you thoughts on it?
Old Feb 8, 2006 | 11:11 AM
Kataklysm's Avatar
Re: ? about prestone anti freeze.
Did you buy the universal kind or the straight green kind? You can mix coolants as long as its not green with dec-xool or anything like that. It is safe for aluminum or it wouldn't be released because just about every radiator is aluminum. You'll be fine, if you see your running hotter just drain and get new coolant.
Old Feb 8, 2006 | 12:06 PM
BLACK Z !'s Avatar
I got the regular coolant,
Old Feb 8, 2006 | 01:46 PM
stingercamaro's Avatar
Prestone non-diluted has the black top and will mix with anything. It is safe for aluminum radiators and it used to be green but the company switched the color to yellow so people wouldn't get confused with the universal stuff and the green.
Old Feb 9, 2006 | 10:11 AM
BLACK Z !'s Avatar
Does prestone make aregular green antifreeze any more? or is this yellow stuff he only thing they have? is it any good? you say aluminuim radiators but what about motors and heads?
Old Feb 9, 2006 | 10:16 AM
94Z28/SSw's Avatar
Yes, the only prestone coolant is 9.99 at Auto Zone, and the 50/50 is 8.99. The regular coolant is a darker green and really thick. The 50/50 is a light green due to the water mix and not as thick. Trust me, I should know, with in the last two week I've had to fill my car 6 times with coolant due to a waterpump change, then opti change, then my lower radiator hose coming off three times, then another opti change, and now I have to pull the water pump again due to the gasket not be on right. So, there you go, that coolant is cheap, I know.
Old Feb 9, 2006 | 10:22 AM
BLACK Z !'s Avatar
Yeah I guess I am just used to a dark green coolant, the stuff I have is not dark and not thick. but it is not pre mix.
Old Feb 9, 2006 | 10:25 AM
94Z28/SSw's Avatar
Well, it may not be really dark green, but it is a lot lighter than the 50/50 stuff they sell.
Old Feb 9, 2006 | 01:42 PM
BLACK Z !'s Avatar
The 50/50 stuff is lighter then the full strengh, do they make a orange dex cool.
Old Feb 9, 2006 | 02:12 PM
moparman's Avatar
Preston does make a Dex-Cool type anti-freeze, and it is orange.
Old Feb 14, 2006 | 09:29 AM
BLACK Z !'s Avatar
Is this stuff pretty decent stuff? is there better stuff that can be picked up local? thanks
I just used it in my Z and my quad, the Z I don't use much and it sits alot so i just want to make sure it is protected. And the quad is mostlyu aluminum so i don't want to ruin that. I just can't get over how light it is, it is almost clear.
RUENUF
Mar 13, 2016 03:37 PM
colts0455
Oct 4, 2015 09:47 PM
MichiganSkip
Aug 6, 2015 09:38 AM
Noct
Jul 14, 2015 01:18 AM
guest
Mar 7, 2003 03:56 PM
