single nozzle setup on LT1 WS6 quick question
Old Feb 1, 2006 | 09:57 PM
69z-28's Avatar
is it easy to run a nozzle style setup in the rubber duct from the MAF to the throttle body? it seems like its all crinkled and theres no good spot to place a nozzle, when compared to like the 90* boot on regular LT1s with the flat areas. was just thinking about that and figured id ask if anyone had any thoughts or ideas.
Old Feb 1, 2006 | 10:32 PM
Nitro Dave's Avatar
Re: single nozzle setup on LT1 WS6 quick question
If you have the ram air hood you are currect. There is not much room there for a nozzle. You could drill and tap the maff end for the nozzle or use a NX maff kit..
Dave
Old Feb 2, 2006 | 09:39 PM
69z-28's Avatar
what about the nitrous works plate system?http://www.jegs.com/webapp/wcs/store...0321&langId=-1
thats the kit that the guy had on the car before i bought it. im thinking about going with the same kit since pulling it off seemed so easy and the plate seems simple and straight forward. plus i dont have to mess with nozzles.
Old Feb 3, 2006 | 07:17 AM
Consider replacing the stock WS6 rubber bellows with the Fernco sewer pipe mod.... $6 at your local Home Depot. Very thick, rigid rubber.
Old Feb 3, 2006 | 07:26 AM
Javier97Z28's Avatar
Moderator
Hey Fred when are we gonna see some new times out of your car? I don't think I've seen an update in years!
Old Feb 3, 2006 | 12:06 PM
My car has not been on the track in 2.5 years. Disappointing, but there are complications that keep me from using it the way it was intended.
Old Feb 3, 2006 | 01:21 PM
Moderator
Damn, that sucks, it's a hell of a setup too
Old Feb 3, 2006 | 03:46 PM
69z-28's Avatar
wow, that looks really nice. im assuming you had to cut it, but it fits with little modification huh?
Old Feb 6, 2006 | 10:01 AM
Nitro Dave's Avatar
If you want a much better desighned plate that will attomize the mixture to the runners better check out our plate system.
Dave
Old Feb 6, 2006 | 11:27 AM
Were you asking about replacing the stock bellows with the Fernco? Its a direct replacement - no cutting. Mine looks "odd" because I don't run an MAF.
Old Feb 6, 2006 | 05:27 PM
69z-28's Avatar
Dave
i checked out that LT1 plate system. it only had one tab for details and not much was listed. can you send me some specs and info on it along with a price?thanks
Injuneer,
i am talking about the goofy shaped one that connects to the throttle body. thats what your talking about right?
Old Feb 6, 2006 | 09:24 PM
Nitro Dave's Avatar
In Juneer.
That looks good.
Dave
Old Feb 6, 2006 | 09:25 PM
Nitro Dave's Avatar
Injuneer,
Yes I will get all the pics off Justins computer at work tommorow.
Dave
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
limige
Aug 17, 2002 12:15 PM
