Component tweeter in Camaro
Old Jan 24, 2006 | 09:22 PM
eagleknight97's Avatar
How many people out there have a component set up for the front speakers and how did you mount the tweeter? I really like my current setup, but unless I have the volume turned up alot, it SOUNDS like my front speakers are on the ground. My HU has DSO(dynamic soundstage organizer) and if I use it and make it so that the front speakers sound like they are at ear level, then it totally messes up how the rears sound. So im looking at getting some components for the front so my front soundstage is where it should be without using DSO.
Current Set Up
Pioneer TS-A1681R - 4-Ways at all 4 corners
Sony CDX-M8810X - Head unit
Sony XM-SD46X Amplifier - 60watts RMSx4
Old Jan 25, 2006 | 10:43 AM
trilkb's Avatar
Re: Component tweeter in Camaro
I'll be keeping an eye on this post. i have aset of alpine 5 1/4 comps..also cant find a place to put the tweeters. i was thinking A pillars....wait just had a CRAZY idea...what if you got an a pillar gauge pod... and put it in there?!? might be something to think about! i might do that even. wow im amazed i just though of that.
Old Jan 25, 2006 | 03:54 PM
VTsullyman's Avatar
The problem you run into at the A pillars is the timing difference. You want botht he highs and lows to hit you at the same time. I will try t get some pics on of tweeters up tonight,
Old Jan 25, 2006 | 05:26 PM
chuckd4more's Avatar
I also thought of that one and the other problem is I have yet to see a guage pod for the pass side. You would probably have to make it yourself. If you're gonna go that far, might as well make them molded into the door with some fiberglass.
Old Jan 26, 2006 | 12:10 AM
Any luck with the pics? Also, the timing difference you talk about, is that an audiophile difference or would it be easily noticeable? Ive been looking for some T/A door panels for my Camaro for a while because they have a tweet location built into the panel, but I havent looked hard and im not quite sure that I like the look of the panel better than my Camaro panel. Would it just be a better idea to buy a pair of Infinity Kappa 63.7i's and put them up front because they have a swiveling tweeter which I could angle up towards my ears. Im not an audiophile as you can tell by my set up, but I would like to work on this a lil more. Thanks for any help
Old Jan 26, 2006 | 08:46 AM
VTsullyman's Avatar
Its a toss up kinda thing. I think most people notice it. Now that dosent mean it bugs them. I wouldent change out the door panels if it was my choice. Stay with the componets they will soudn alot better in the end. Well worth the effort. IM on campus all day today for classes but hopefully tonight i can get some up. Did your componet kit come with a flush mount? Most do. All you need is a hole saw of the correct size and pict a spot on the carpet on the door pannel. Your want it mounted high and as close to the edge as possibul. I have noticed that the windows play a larger role in my osund stage now than ever before in my other cars. If you dnt have power windows than you can do what i did on my first camaro. Use a surface mount and pu the tweeters right where the power window controls would go. You get the best sound staging out of that setup. How much work are you willing to do? What mounting option came wiht your speakers?
Old Jan 26, 2006 | 09:16 AM
I dont have any component speakers yet, but im trying to figure out what I might want to do over the summer when im home from school.
Old Jan 26, 2006 | 05:47 PM
KyleBlue85Iroc-Z's Avatar
As of right now I have no pictures of my setup yet, but I've got the Alpine Type-S components in my front doors. I put the tweeters up on the black piece covering the side mirrors, using the angle mounts supplied with them. When the doors close they aim pretty much to the center of the car, about chest level I would say.
I custom mounted the mids and crossovers in the original Bose speaker mounts in the door. I cut up the old amp holders and made them work for the crossovers, that way I wouldn't have to remote mount them somewhere under the dash.
Also, I wanted sound from the rear, but not highs. So I went with some 6.5" Kicker mid-basses in the sail panels and they don't sound too bad. They're no subwoofers, but they help a LOT in the lower end where the components can't get to. Now all I need is a 10" sub in a stealth box and it'll be an excellent sound.
Good luck man. I did all this for the same reason you're saying, because I couldn't stand hearing all the music from down at my feet.
Kyle
PS - I'll try to get some pics sometime this weekend and put them up for ya.
Collector Car
Jan 5, 2015 10:58 AM
Brian Demeter
Aug 21, 2002 02:07 PM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
BigED
Jul 26, 2002 09:22 AM
