t56 transmission mount
Old Jan 21, 2006 | 01:21 PM
MC'SZ28's Avatar
I broke the stock transmission mount and bought a new one at autozone and it is making the car have a lot of noises and vibrations and noises. Whatever the case maybe I have found that the polyurathane mount is bad from a the last camaro z that i owend. I notice that there are differnt positions to mont it in. More to the front of the car or to the back. I have moved it twice. Very little inprovement.
Any ideas or suggestions.
Thanks Guys,
Old Jan 21, 2006 | 01:31 PM
pHEnomIC's Avatar
Re: t56 transmission mount
Sometimes the mounts have to break in. If you are sure you mounted it correctly, give it some time.
Also, since you broke your mount, it is possible that you broke something else as well such as the driveshaft or something in your rearend.
Old Jan 22, 2006 | 12:36 AM
MC'SZ28's Avatar
what do you mean, I might have broke something in the dirive line. How would I know. To me it sound like a bad mount.
Old Jan 22, 2006 | 06:03 AM
Dave89IROC's Avatar
is it still clunking?
Old Jan 22, 2006 | 07:36 AM
SFB767's Avatar
Get an LS1 mount from your GM dealership.
I broke my stock mount about 3K miles ago, bought a polyurethane mount from Energy Suspension and it rattled my car everytime it shifted and constantly vibrated my center console. I couldn't take it anymore and bought the stock mount and the car feels much better.
Old Jan 23, 2006 | 05:25 PM
MC'SZ28's Avatar
yes it is clunking
MC'SZ28's Avatar
yes it is clunking
Old Jan 23, 2006 | 05:32 PM
silentsprintero's Avatar
the poly mounts are a lot stiffer so they're just sending all the vibrations from the transmission straight to the chassis. i also notice on the Energy Suspension poly mount you had to push the tranny over like 3mm to line up the bolts which could also have some play in the vibrations. i just went to GM and bought a new factory one and its smooth again. all in all, poly mounts suck for daily driving
Old Jan 23, 2006 | 06:03 PM
OBE1 95Z28's Avatar
I too removed my poly mount due to excessive vibration and went with the 1LE design, which I believe is now the stock part sold by GM. Some guys are also using the LS1 mount in a LT1.
Old Jan 24, 2006 | 09:04 AM
sabre81's Avatar
When i had an A4 in this car, the poly mount rattled my teeth out. When i swapped to a T56, i put the poly mount in for ****z and it was smoother than the stocker mount. Go figure.
Old Jan 26, 2006 | 12:30 AM
similar question to original thread-as i stated above i just put in a new tranny mount from GM and its awsome, but under a load the shifter still moves a tiny tiny bit, motor mounts going bad/loose?? or is it just because the OEM mount is rubber and it has that much flex in it?
Old Jan 26, 2006 | 07:30 AM
Originally Posted by silentsprintero
...or is it just because the OEM mount is rubber and it has that much flex in it?
Most likely.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
Jazsun
Dec 29, 2014 12:14 PM
Timberwolf
Sep 2, 2002 10:42 AM
