thrust angle?
Old Jan 19, 2006 | 08:35 PM
92/95TransAm's Avatar
thrust angle?
i put my car on the alignment rack and measured my alignment specs only to see a -28 degree thrust angle. my suspension is all stock. no adjustable parts were installed. what could be throwing this off so far? there is a little movement on the right rear wheel front to back if i put on the parking break and push the car front to back but just barely noticable. it doesnt seem like it is enough to be -28 degrees though. any opinions?
thanks.
Old Jan 19, 2006 | 09:56 PM
respectirocz's Avatar
Re: thrust angle?
bent panhard bar?
bad bushings?
Old Jan 22, 2006 | 08:06 PM
Re: thrust angle?
i will have to look at these. is there a difference in length from the third and fourth gen panhard bar. it has junk yard numbers on it so i am assuming its been replaced.
Re: thrust angle?
Re: thrust angle?
Old Jan 22, 2006 | 08:23 PM
Re: thrust angle?
the length is exactly the same, the rear suspensions are exactly the same on third and 4th gens
if that is the case, then u have the perfect excuse to buy an adjustable panhard bar
Old Jan 24, 2006 | 03:44 PM
Re: thrust angle?
thanks i will have to check it out.
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
Aug 7, 2015 01:26 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
realistyc
Jul 28, 2015 07:32 PM
Fastbird93
Jun 3, 2015 05:56 AM
