rear end question
Old Jan 16, 2006 | 08:38 PM
gillt1's Avatar
rear end question
Hi, I'm looking to up grade my 95 z,now I'm running 2.73gears with series 2 carrier,I would like to up grade to 3.42,can anyone suggest best make and if possible part #s Thanks for any help.
Old Jan 17, 2006 | 04:31 PM
camaro777tom's Avatar
Re: rear end question
Let me know if you need a source for a spacer and longer bolts. Cost me like $50 shipped, but I don't have the company info in front of me.
Old Jan 18, 2006 | 01:44 AM
Z28_95RIDE's Avatar
I would recommend drivetrain.com. I bought a Motive spacer from a place in Michigan but I got the answers to my questions from Shep at http://www.drivetrain.com
That Motive spacer needed some chamfering to fit against the Auburn differential's flange. The radius on the flange is greater than the chamfer on the spacer. It took a while to whittle the spacer to fit flat against the differential's flange.
You might already know this but a spacer is a weak link. First of all, it doesn't fit on the pilot of the differential but is located by the bolts themselves. This doesn't seem like it would give a good location but amazingly it does. Hard launches with drag slicks will probably cause a spacered rear end to fail. If you have an automatic transmission, you will be much safer.
good luck
Old Jan 18, 2006 | 06:02 PM
NstyLT1's Avatar
Summitracing.com part number RMG-490051 is 205.95. Personally, I would go with the 3.73s thats what i am running in my Z and I love them. Granted the cruising RPM will be a little bit higher than what ur running now.
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
