7000+ rpm on stock PCM?
Old Oct 31, 2002 | 01:17 AM
mastrdrver's Avatar
I have some saying it isn't possible and others say it is, so now I'm confused. Is it possible to go past 7000 rpm on stock pcm? If not, what is the most user friendly setup to go with: FAST, DFI, etc whatever. What are those guys with the huge solid roller cams from Cam Motion running for pcm? I know they have to be turning atleast 7000 rpm right? Anyway, thanks for the help. Also someone said the the Vette pcm can go higher that the F-body, is this true.
Thanks,
Jeremy
Old Oct 31, 2002 | 03:39 PM
mastrdrver's Avatar
TTT, I need help. I need to know this for my cam selection.
Old Nov 3, 2002 | 06:41 PM
KTamez's Avatar
Most of the guys you see on this board ven with the solid rollers are using the factory PCM.
Just do what you can within your budget. Aftermarket engine management will set you back $2k+. Call the Cam manuf. and see what they can grind for you to stay under a 7k rpm shift point.
I myself have FAST/Speed pro management, anbd wouldn't do it any other way (in comparison to DFI, E-motive, etc)
Good luck!
Old Nov 3, 2002 | 06:55 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
I shifted my solid roller 383 at 7,200 with the stock PCM. I've heard the vette pcm's are good until 7,400, but you can't use them on an f-body.
Old Nov 4, 2002 | 09:41 PM
blown95ta's Avatar
OBD1 wont go past 7000 rpm., trust me
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
