AIR pump system on my '99 Z28
Old Jan 12, 2006 | 07:39 PM
shmuck2003's Avatar
Hi guys,
I am having trouble with my '99 Z28 throwing error P0418 and P0412, which are both related to the "secondary AIR..." system. the 25A AIR fuse is blown, i replaced it with a 30A to see, and it blew instantly. when i remove the AIR relay, it does not blow the fuse. when I replace the relay, but disconnect the plug from the AIR pump, it still blows. I'm assuming at this point that it is a short in the wiring harness, somewhere between the relay and the actual AIR pump.
Here's the bigger question: the car is due for smog, I live in CA. if i replace the fuse, remove the relay, will it still throw the error codes? and, assuming they stay cleared, will I pass CA smog?
Joe
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
Jan 13, 2015 09:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
