Replacing fuel filter on LS1
Old Jan 7, 2006 | 07:11 PM
brians96Z's Avatar
Could someone tell me more about how to replace the fuel filter on my 98 TA? Exactly where is the filter located, and how do I disarm the system to replace it? Is there anything else I need to know? This is my first time replacing one......
Old Jan 7, 2006 | 07:25 PM
sir dyno's Avatar
Re: Replacing fuel filter on LS1
The fuel filter is located on the underside of the car by the rear driver side tire.
Remove the fuel gas cap. Get lots of raggs. Remove the bolt holding the gas line -removing this bolt will lessen the pressure put on the plastic gas line when removing it from the fuel filter- and remove the filter. Once you remove the filter some gas will still pour out then it will stop and you can then put on the new filter, be carfull when taking off the filter you don't want gas in your eyes. Its not to technical at all.
Old Jan 7, 2006 | 07:27 PM
2001NBMZ28's Avatar
www.installuniversity.com has instuctions/pics.
Old Jan 7, 2006 | 07:28 PM
johnny6's Avatar
Make sure you wear eye protection, because there's a slight spray and it will get in your eyes, learn from me gas in eyes=pain.
Old Jan 7, 2006 | 07:31 PM
Since the filter is the same as used on the LT1 cars, replacement should be the same. The schrader valve location will be different.
Old Jan 7, 2006 | 07:48 PM
brians96Z's Avatar
Thanks guys!
Old Jan 7, 2006 | 11:21 PM
AlfredB18's Avatar
Well, you're half on to something here. Removing the gas cap equalizes the pressure in the tank, but does nothing to the pressure between the fuel pump and engine.
If you want to get rid of the fuel in the lines, pull the fuel pump relay in the underhood box, crank the engine for a few moments, then the fuel is gone.
No fuel spills.
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
