Lt1 coil
Old Jan 7, 2006 | 04:16 AM
LT193's Avatar
Lt1 coil
Does anyone have 2 connectors going into there coil? I only seem to have one on my harness that plugs into the coil yet its a 2 plug coil.
Old Jan 7, 2006 | 07:32 AM
Re: Lt1 coil
My MSD harness has only one plug.
Old Jan 7, 2006 | 09:23 AM
Fastbird93's Avatar
Re: Lt1 coil
My Accel 300+ on my 93 is the same way. Both of the factory plugs go into the Accel box and then the one plug from the Accel harness goes into the coil.
I believe it's like that with almost all aftermarket ignition boxes out there.
Old Jan 7, 2006 | 09:30 AM
Mtrhds94Z's Avatar
Re: Lt1 coil
You do have a '2nd plug'..
It is now plugged into the MSD harness[the grey plug in the pic is the 2nd plug]
Old Jan 7, 2006 | 06:48 PM
LT193's Avatar
Re: Lt1 coil
Right the 2nd plug is like plugged off or something, ive only been running one into the coil. Even after just looking at it i disconnected my ignition msd box and there is only one plug that goes into the coil, its the white one. The other one im not sure, there is a 3 wire thing that is in a molded squre. Not sure but my car worked fine for over a year with one plug in the coil. Is this normal on 93s?
Old Jan 8, 2006 | 03:35 AM
LT193's Avatar
Re: Lt1 coil
anyone?
Old Jan 8, 2006 | 08:55 AM
Kevin Blown 95 TA's Avatar
Re: Lt1 coil
I looked at that once and determined that the dual connectors are redundant. Not sure why the factory had it that way other than convenience of hooking up the wires.
Old Jan 9, 2006 | 12:05 PM
LT193's Avatar
Re: Lt1 coil
So i guess its ok then that i only have one connector lol.
Old Jan 9, 2006 | 04:10 PM
Re: Lt1 coil
If you are using an MSD harness, only one connector goes on the coil, just like the pic I posted.
Old Jan 9, 2006 | 04:57 PM
zway2go's Avatar
Re: Lt1 coil
ok guys i posted a question about my eng dieing on me maybe i just found the problem on this form...please not the pic above of the front left side with coil...
On my eng that gray and black plug to the left is pluged into my coil ?.where that black plug thats in the coil is the pic i have no idea at this time where its pluged into on my eng....could some one please tell me in that pic shown above ...what is that gray and black plug ,pluged into in that pic...thinking this could be my whole problem here...im think some one had this all apart at 1 time when a valve job was done some time ago before i bought the car and they hooked the wrong plugs to the wrong things...??????help please..Thanks Bob .. zway2go@aol.com
Old Jan 9, 2006 | 05:25 PM
zway2go's Avatar
Re: Lt1 coil
i ment that gray/black plug in the pic on the right side of pic but left side of head/block.thanks BOB
Old Jan 9, 2006 | 11:11 PM
Re: Lt1 coil
It plugs into the MSD harness that you only would have with an MSD ignition box. As stock, the grey and black connectors plug into the coil instead.
Old Jan 10, 2006 | 01:58 AM
LT193's Avatar
Re: Lt1 coil
Im not sure how but my car has been working forever on just the grey one going into the coil man. I have an MSD box but ive only had one plug into the coil the entire time. I bought the MSD box, hooked it up with the qwik connect harness, but i never had 2 connectors im missing the black one completly. I have one into the qwik connect harness (the grey one) and one from the harness into my coil. Is this a problem that i am totally missing the stock black one from the harness?
Old Jan 10, 2006 | 07:49 AM
Re: Lt1 coil
Don't know what to tell you. A stock harness should have two plugs. If it has worked that way "forever", I doubt it is the source of a new problem.
Old Jan 10, 2006 | 08:19 AM
Tom Piper's Avatar
Re: Lt1 coil
Previous to '96, they should have had two siamesed plugs (one black and one gray, I think).
In '96, the system went to one plug on the coil.
Did someone change your system to a '96 coil?
Tom Piper
