Will they fit?
Old Jan 4, 2006 | 01:52 AM
BlownLS1's Avatar
Will they fit?
I looking at Fikse FM5
The 2 rear wheels are 18x 11.5" with 9" backspacing which yields a 2.75" offset (70mm)
The 2 front wheels are 18x 9.5" with 7.5" backspacing which yields a 2.25" offset (57mm)
bolt pattern is 5 on 4 3/4 (120.65mm)
Will this clear? What should I be looking for
What does the specs mean exactly?
Old Jan 4, 2006 | 06:50 AM
Re: Will they fit?
The max backspace for the rear wheels is about 8.0". Those of us with the 7.93" BS 17x11 ZR1's generally have to do some hammering. 9.0" BS wheels would require a mini-tub. An 11.5" wide wheel would need an offset of 45mm or less, and then they are going to be outside the fenders.
The fronts are correct.
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
Jan 23, 2015 01:13 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
