T rex pump
Old Jan 3, 2006 | 11:03 PM
RICEFEDZ28's Avatar
T rex pump
Is this worth buying or should I just go 255 walbro?
Old Jan 3, 2006 | 11:30 PM
BADST95's Avatar
Thumbs up Re: T rex pump
An intank pump is much better. At a certain point, an in-line pump can become a restriction.
Old Jan 3, 2006 | 11:42 PM
RICEFEDZ28's Avatar
Re: T rex pump
I'm only runnin 9psi for now.
Old Jan 3, 2006 | 11:53 PM
Alvin@pcmforless.com's Avatar
Re: T rex pump
I've had alot of good luck with a T-rex and a stock intank pump..
To the order of 550rwhp
Old Jan 4, 2006 | 01:45 PM
97WS6Pilot's Avatar
Re: T rex pump
I use a walbro intank and the TREX inline. When I remove the TREX I cannot get the 65 psi necessary for 30# injectors and my 9psi setup. The walbro by itself peters out at about 55psi. If your looking for flow and high pressure I suggest the TREX. Or you could go with 42# injectors stock fuel pressure and just the walbro.
Also like Alvin said I don't think the stock intank pump would be that big of a restriction even though it flows less than the TREX.
You can get a complete TREX kit from procharger for a little over $200 That comes with all the wiring, relays, hardware and plumbing. It bolts on in about 1 hr.
Old Jan 4, 2006 | 02:13 PM
Re: T rex pump
You put work into a fluid stream... you get work out of a fluid stream..
To think the stock pump is some HUGE restriction is rediculous.
I would have rather gone with a nice walbro pump but I didn't feel like pulling the tank down and had low HP goals.
Old Jan 4, 2006 | 02:18 PM
RICEFEDZ28's Avatar
Re: T rex pump
I'm running a walbro but its the step below a 255 don't remember what size. I paid like 130 for it.
HectorM52
Jul 30, 2017 11:46 AM
4586
Apr 24, 2015 01:03 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Dec 17, 2014 11:00 AM
T-REX
Sep 1, 2002 02:28 PM
