Clutch Want Disengage
Old Jan 2, 2006 | 06:52 PM
1986camaroz28's Avatar
JUST PUT A NEW C,PP,TOB IN MY 86 Z, NEW MASTER AND SLAVE, DAMN CLUTCH WILL NOT DISENGAGE. SLAVE IS WELL BLEED, SLAVE HAS PLENTY OF TRAVEL. WHAT ELSE SHOULD I CHECK??
Old Jan 3, 2006 | 07:04 AM
cehan's Avatar
Re: Clutch Want Disengage
If you're sure the hydraulics are working, the only other thing that it can be is that the disk is stuck to the pressure plate, or flywheel, or both. I had that happen to me. I installed the clutch and transmission while the engine was out of the car. It was a couple of weeks before I finally was ready to fire it up. The clutch would not release. I pulled the trans back off, and I found that the disk was stuck to the pressure plate. The only thing I can figure is that humidity got sucked up by the organic material in the disk and it "glued" itself to the pressure plate.
Chris
Old Jan 3, 2006 | 10:02 AM
Kwiksilverz28's Avatar
Bad master cylinder?? I know you changed it, but defective?
Old Jan 3, 2006 | 10:49 PM
thanks for the advice, i'll try a new master tommorrow and if that doesn't work i'll pull the tranny!!
thanks again
Old Jan 4, 2006 | 10:35 PM
replaced master cyl today and worked like a charm. thanks for the help!!!!!
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
