TSP Rumbler
Old Dec 28, 2005 | 10:59 PM
frusciante fan's Avatar
TSP Rumbler
http://texas-speed.com/shop/item.asp...d=195&catid=46
does anyone here have this kit? how does it sound? also, where exactly do the mufflers go? i don't see them in that pic.
Old Dec 29, 2005 | 01:22 AM
69gto96z's Avatar
Re: TSP Rumbler
I have it on my LT1 and LOVE it. It has a real deep rumble, and is loud, but not as loud as the loudmouth. The muffler is an 18" dynomax bullet, if you look in the pic at the front of the exhaust, you will see where the piping gets bigger before it goes over the rear axle. That is the muffler. Check out www.ls1sounds.com for some cound clips of it on an LS1.
Old Dec 29, 2005 | 08:24 AM
Re: TSP Rumbler
i'm just unsure how it might sound with my V6. 3" sounds a little too big. and those black things on the end, are those the tips that come with it? i would be fine with just having the end pipe cut at a 60* angle. also does this kit come with a cat? will this mess with my 02 sensors?
it basically looks like some 3" pipe and 1 glasspack. if that's the case i could probably have a homeade one for less.
Old Dec 29, 2005 | 05:34 PM
SFB767's Avatar
Re: TSP Rumbler
Buy it without tips and you can add any tips you want.
It won't even touch your cats or your O2s.
Cat-back exhaust = it goes from the catalytic converters to the tailpipes.
Old Dec 30, 2005 | 06:27 AM
myslowcamaro's Avatar
Re: TSP Rumbler
i have it and like it
Old Jan 26, 2006 | 11:48 AM
robb4964's Avatar
Re: TSP Rumbler
I have this on My LS1 and OMG it sounds BADAZZZ.....I am gonna put one on my 97 LT1 transam next.
I was actually looking for sound clips of it on an LT1.
Old Jan 26, 2006 | 12:06 PM
teke184's Avatar
Re: TSP Rumbler
for a v6 you're probably fine just putting a bullet muffler in place of the stock muffler.
or putting one in the I-pipe before the axle and then running a Y behind it to run dual tips.
3" isn't too big for a v6...you won't lose anything, but you probably won't gain much either, other than sound.
you could always try something like a sweet thunder chambered muffler on your stock system. they sound great!
Old Jan 26, 2006 | 11:36 PM
robb4964's Avatar
Re: TSP Rumbler
I was thinkin the same thing.
A muffler would probably sound better on a V6 then the catback.
White WS6
Jun 4, 2004 01:36 PM
Articblast
May 30, 2004 09:08 PM
Z28Venom
May 16, 2004 07:22 PM
LetMeBurnU
Apr 12, 2004 06:12 PM
ZYAPONY
Apr 8, 2004 03:38 PM
