How will I like this Exhaust Setup????
Old Dec 26, 2005 | 11:24 AM
79Cutlass's Avatar
I have heard the GMMG exhaust and loved it! I was thinking about putting the similar style Summit chambered mufflers on my 79 Cutlass with a Gen 1 350. How do you think that would sound? It has mid-length headers, no cats, 2.5" X-Pipe system and exits after the rear tires. Would there be a lot of resonance? Any input welcome! Thanks
Someday a LS? Motor/T56 will live inside my Cutlass!
Old Dec 26, 2005 | 01:25 PM
Kataklysm's Avatar
Re: How will I like this Exhaust Setup????
I highly doubt it will sound like a GMMG. It should be pretty loud and sound good though. I think it will drone pretty hardcore.
Old Dec 26, 2005 | 02:58 PM
79Cutlass's Avatar
I don't know if i'll do it now. I don't want it to resonate like crazy inside. Not sure though.
Old Dec 26, 2005 | 05:44 PM
teke184's Avatar
if it exits past the rear wheels the resonance shouldn't be too bad. not any worst than most other true dual systems you could run.
the reason most true dual kits resonate so bad on Fbodies is that they usually end under the car...causing the noise to reverberate between the ground and the car.
i say go for it
Old Dec 26, 2005 | 08:57 PM
Greed4Speed's Avatar
I can sum the sound up in 2 words: glass packs
Old Dec 26, 2005 | 10:45 PM
79Cutlass's Avatar
I will probably end up going for it. Summit Chambered Mufflers. What length to get?
Old Dec 27, 2005 | 07:58 AM
With all stick mufflers, make sure the internal diameter does not neck down. Most stick mufflers will have an internal tube diameter 1/4" smaller than their inlet/outlet diameter.
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
alex5366
Feb 17, 2015 08:12 PM
Ken95Z28
Aug 21, 2002 04:32 PM
