v6 to v8 Lt1?
Old Dec 19, 2005 | 05:35 PM
geno123's Avatar
v6 to v8 Lt1?
A friend of mine , as a gift gave me a 1995 Lt1 5.7 engine.Was wondering what needs to be done,have a 97 v6 camaro convertible 30 year edition.What kind of mods need to be done,will the tranny fit,how about the pc,will it work.Sorry so many questions, just would like to know if it can be done.Thanks for ur help..
Old Dec 19, 2005 | 07:40 PM
Antz97ZNJ's Avatar
Re: v6 to v8 Lt1?
to make the answer plain and simple ALOT
Old Dec 19, 2005 | 08:11 PM
MyShibbyZ28's Avatar
Re: v6 to v8 Lt1?
Don't be so negative
Yes a lot is needed though. Hmmmm...if it is complete, like harnesses, PCM, ECM, everything from top to bottom, then it will be a lot quicker.
But, it is not very hard from what I have heard, it is just very time consuming. I do not think you need a new transmission if it is a 4L60E.
Old Dec 19, 2005 | 09:11 PM
jlaudioholic's Avatar
Re: v6 to v8 Lt1?
this site helps a whole lot http://www.tacreationsusa.com/3_4_3_8_v6_to_lt1.htm
and this one
http://www.hpsalvage.com/
You will have to change the tranny, bellhousings are diffrent. Plus everything else listed on that site. If your not a wiz with wiring then could just try to find a 97 PCM and engine wiring harness to make things a whole lot easier, or else you'll end up with a big hack job. Also I have an LT1 engine cradle for sale if interested, PM me for details.
John
Old Dec 20, 2005 | 04:06 PM
geno123's Avatar
Re: v6 to v8 Lt1?
Ok.seems a little overwelming,might need to think more about doing the switch.Might not be worth the try.Thanks alot for the information.
Old Dec 20, 2005 | 06:53 PM
ReNxWar's Avatar
Re: v6 to v8 Lt1?
If you decide against the V6 to V8 swap you can just put the V8 in a gokart or something. Hell, imagine a LT1 powered dune buggy. *Droool*.
Old Dec 20, 2005 | 09:48 PM
Re: v6 to v8 Lt1?
Here are a few more options for you:
you could sell it to help offset the cost of a turbo set-up http://www.force-fed-fabrications.com/index2.htm
or a supercharger set-up http://www.rksport.com/product/p_010910283/view_detail
or a N/A set-up http://www.abbottracingheads.com/gm3800.html
or you could just keep it around and eventually drop it into a 3rd Gen F-body or mabey even stumble upon a nice 1st gen camaro to stuff it in.
John
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
