Tranny Issues
Old Dec 14, 2005 | 03:14 PM
rg1993ss's Avatar
Unhappy Tranny Issues
Just bought a 1993 Z28 with auto trans. The trans will only work in 1St and reverse. Any ideas about was could be wrong or do I need a new tranny. It is their some thing else that could be wrong?
Old Dec 14, 2005 | 03:28 PM
Cmr0z28's Avatar
Re: Tranny Issues
Rebuild time!
Old Dec 14, 2005 | 03:30 PM
km9v's Avatar
Re: Tranny Issues
Get your money back.
Old Dec 14, 2005 | 03:41 PM
rg1993ss's Avatar
Re: Tranny Issues
I only paid $300 dollars for it runs great and has a 2 year ond paint job and I knew the trans would not shift. Just trying to see if their could be another issue with the trans. Thanks Ray
Old Dec 14, 2005 | 03:42 PM
km9v's Avatar
Re: Tranny Issues
Well, then a rebuild is in order. $300 is not bad.
Old Dec 14, 2005 | 05:23 PM
12SCNDZ's Avatar
Re: Tranny Issues
The '93 Camaros still used a governor. This is the large round cover at the rear/drivers side. There's a possibility that the valve in the governor is stuck, or the governor gear is bad/broken. Another possibility is that the TV valve is sticking.
Try this...Start the car, and let it idle. Lift the hood and locate the TV cable. You'll see a small black "button" that attatches it to the throttle body. This may be under a black plastic cover. Once you locate it, pull the wire part of the cable all the way forward a few times and let it snap back.
After you do this, try driving it again. Sometimes this will free up a stuck TV valve. Even if this works, it's probably only a short term fix. This would indicate that something is coming apart in the transmission which would neccessitate a rebuild.
If your problem isn't in one of these places, it could still be a stuck valve. You're fluid condition will help diagnose this. Is it still pink? Does it smell burnt? There are many internal problems that will cause this, also.
If you need any further help, feel free to call me. I'll try walking you through a couple of things to try.
Frank
302-250-1202
Old Dec 14, 2005 | 09:05 PM
rg1993ss's Avatar
Re: Tranny Issues
Thanks for the info Frank I will check the tv cable and governor this weekend and if I need some help I will give you a call. I am new to this board and have seen several post about your knowledge of these transmissions so I may send the trans to you. Thanks Ray
BigWil
Mar 29, 2015 12:24 PM
jackpawt883
Feb 26, 2015 09:04 PM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
Snoman73
Nov 17, 2014 07:22 PM
