TB Bypass Question
Old Dec 13, 2005 | 05:00 PM
MarcR94v6's Avatar
TB Bypass Question
I've read the many threads on it, but one thing was never made clear...After I remove the two coolant hoses going into the throttle body and join them together with a 3/8" metal hose and clamps, what about the hose ports? Do I just leave them open? Or do I plug them somehow? And am I to understand that no coolant will be going throgh the throttle body after this is done, only air?
Old Dec 13, 2005 | 05:27 PM
OBE1 95Z28's Avatar
Re: TB Bypass Question
On the LT1 engine, coolant flows in one port and out the other, therefore when you bypass the TB, nothing flows through it. No need to cap off the ports on the TB; some rubber vacuums cpas will keep the spiders out
Old Dec 13, 2005 | 06:14 PM
MarcR94v6's Avatar
Thanks, just something I always wondered that I felt was left out of a lot of tb bypass instructions.
Old Dec 13, 2005 | 07:49 PM
crasher88's Avatar
just a waist of time and money by doing the tb bypass its an old racer trick that does nothing.
Old Dec 13, 2005 | 08:17 PM
MarcR94v6's Avatar
I've seen dyno sheets that say different. On a website I found that details instructions of doing it.
Buuuut, let's not start that debate again. Let's just agree that it is subjective.
Old Dec 13, 2005 | 09:23 PM
OBE1 95Z28's Avatar
6 HP according to this dyno result:
http://www.ws6.com/mod-8.htm
Old Dec 14, 2005 | 11:37 AM
MarcR94v6's Avatar
It still doesn't make sense to me that no coolant will make it cooler, but I'll try anyhow, possibly take it off if something isn't right, thi is my daily driver afterall. Good find on the dyno sheet.
Old Dec 14, 2005 | 12:44 PM
soul strife's Avatar
Well coolant is still HOT and it's running through where air is. The hot coolant heats the air. So, no coolant = lower air temp.
Old Dec 14, 2005 | 01:55 PM
)2overt SS's Avatar
Exactly
Even though it's called coolant... it's still, what? 230 *F? Much hotter than the TB will ever get if the coolant isn't running through it.
And FWIW, doing the TB bypass doesn't gain you xHP (I've heard anywhere from 1-7HP) Rather it prevents you from losing it once the coolant starts circulating, which heats the incomming air.
Old Dec 14, 2005 | 02:52 PM
OBE1 95Z28's Avatar
Quote: "And FWIW, doing the TB bypass doesn't gain you xHP (I've heard anywhere from 1-7HP) Rather it prevents you from losing it once the coolant starts circulating, which heats the incomming air."
Not wise to race your car if it's not up to operating temperature, which means your coolant temperature will be 180 +.
Old Dec 14, 2005 | 10:15 PM
crasher88's Avatar
yeah but its going though there for a reason. I could see if you lived down here in the southern states and in the summer months but now that its winter I would really be affraid of the TB icing over, yes I have herd of it happening before. Especialy if you lived in the northner states. But i'll drop it at that its a controversial subject and every one has their own opinions on the matter.
Old Dec 14, 2005 | 11:11 PM
00cls1camaross's Avatar
in phx it doesnt get below 45
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
lbrowne
Nov 13, 2011 04:25 PM
slocody
Feb 10, 2003 01:04 PM
RedLineRev
Jan 23, 2003 03:51 PM
