LT1 Switch ideas
Old Dec 12, 2005 | 08:11 AM
Scotts94_z28's Avatar
LT1 Switch ideas
Im looking for an idea on how and where to mount my nitrous switches. Im going to need a switch to arm the system, for the bottle heater, and for the purge. It doesnt need to be hidden since the bottle will between the rear seats and there will be guages on the pillar but i just would like to see what everyone else has done.
Old Dec 12, 2005 | 12:17 PM
nfa's Avatar
nfa
Re: LT1 Switch ideas
Im using the ashtray for my arm, purge and bottle warmer switches. I dont want to have anything out in the open b/c i know some dumb@ss is going to fiddle with the switches when sitting in the passenger seat!
Old Dec 13, 2005 | 01:59 AM
Cmr0z28's Avatar
I have mine on the knee panel, under/next to the steering column.
Old Dec 13, 2005 | 07:55 AM
In my Formula, I made a small box that fits in the door map pocket, with the purge, master arm, heater and remote bottle valve switches in it, plus indicator lights for the arm and heater switches. Not sure it the map pockets in the Z28 doors are the same, or perhaps mounted too far back compared to the Firebird doors. The space on the console is already used for the line lock and Gear Vendor switches.
You can sort of see the panel in the map pocket in this picture (the server with all my photos is down, or I'd show you a closeup):
Old Dec 13, 2005 | 09:53 AM
LWillmann's Avatar
I went to my local stereo shop and got some ABS plastic, black, that is textured like the dash. I then removed my ashtray, and cut a piece of that plastic that takes the place of the ashtray and mounted my switches to that.
The lid for the ashtray opens and closes without problems. If it's closed and you didn't know better, you'd never know they are there.
Old Dec 13, 2005 | 08:07 PM
anyone ever cover the hole under the stereo and temp controls just behind the ****er and install them there?
Old Dec 13, 2005 | 08:23 PM
my94blackz's Avatar
I did mine a lil custom, dont have any pics but heres a description. I got the harris speed works switch plate, but insted of in the ash tray, I took the ashtray lid off and molded a peice of aluminum to the EXACT size and shape as the lid then cut a hole in the aluminum, the same size as the switch panal. Put the switch panal and secure it into the aluminum peace wire it then mount it where the originall lid would go. Its looks great and works good to. The best part about it is that you dont have to reace out of the way to activate it. When i race at the strip it cant stick untill second, so ill pull second then lay into it. The switch panal has 4 rockers switches then a push button in the center.
Old Dec 16, 2005 | 12:13 PM
12SCNDZ's Avatar
I had the same question. I made an addition for my ProStick housing for mine. The blank spot on the left is where the purge button will go. Of course this idea only works if you plan on pulling the console out, like I'm doing.
Frank
Old Dec 16, 2005 | 05:12 PM
Cmr0z28's Avatar
Frank, you should have made the Nitrous (cold) blue, and the heater (hot) red
At least that's what I did with my switches....
Old Dec 16, 2005 | 09:57 PM
oneslowz28's Avatar
Frank
please tell me where you got that shifter from ive been looking for one for months. and will it work with the 4l60e
edit: i just found it in the summit catalogue. and it looks like i just have to order the guide plate for a 4 speed drive pattern. is this right?
Old Dec 17, 2005 | 07:46 AM
n2oCamaro's Avatar
Old Dec 17, 2005 | 08:35 AM
MyShibbyZ28's Avatar
Originally Posted by n2oCamaro
In that picture, where the hole is with the three switches, that's where I put mine...even though they aren't for nitrous.....
Old Dec 17, 2005 | 08:48 AM
12SCNDZ's Avatar
[QUOTE=oneslowz28]please tell me where you got that shifter from ive been looking for one for months. and will it work with the 4l60e
edit: i just found it in the summit catalogue. and it looks like i just have to order the guide plate for a 4 speed drive pattern. is this right?[/QUOTE
Yup...B&M sells a seperate 4 speed gate plate. Summit or Jegs are the 2 cheapest places I found for the shifter.
Frank
Old Dec 17, 2005 | 05:43 PM
oneslowz28's Avatar
thanks frank. does everything hook up like normal or do i have to modify the cabels? and also would you be willing to make a switch panel like you have for it?
thanks charles
Old Dec 17, 2005 | 07:08 PM
12SCNDZ's Avatar
The ProStick comes with it's own cable and transmission bracket. You'll have to disable the park lock cable to use a ProStick.
The biggest stumbling block about using a ProStick is the carpet. The factory carpet is cut out under the console. Finding carpet that wasn't cut was a little difficult. I finally found it from Nifty Pro Line, which is a division of Lund truck accessories. http://www.niftyproducts.com/nifty_c...arpet_car.aspx
It's molded carpet that matches the factory gray carpet, and has no cuts in it, which makes it an excellent choice to use with my Jaz seats, too. It's not in the car yet, but it's looks to be of great quality.
If you decide to go with a ProStick, shoot me an e-mail, and we'll see if we can make you a switch panel.
Frank
