Any Tips/Advice before Changing Rack and Pinion??
Old Dec 11, 2005 | 11:55 AM
Bow94z's Avatar
i am going to be replacing my Rack and Pinion complete unit with inner tie rods on my 94 z28. Any troubles people run into i should be aware of? it doesnt seem that hard.
Old Dec 11, 2005 | 01:22 PM
OBE1 95Z28's Avatar
Re: Any Tips/Advice before Changing Rack and Pinion??
Straight forward. Measure the placement of the outer tie rods to the original rack carefully to set your new rack correctly to get your toe in alignment as close as you can to drive the car to an alignment shop. You're also ging to need a 18mm line wrench to remove the hose from the rack.
Victor Lamb
Aug 26, 2017 02:52 PM
Jun 6, 2015 08:27 AM
mspennyhughes
Mar 1, 2015 03:50 PM
siguy
Nov 27, 2014 10:07 AM
