More 3rd Gen questions
Old Dec 9, 2005 | 09:03 PM
UtOhCop's Avatar
I appreciate how nice you guys are in this forum.
88 Camaro with a L98 swapped in. Car has some problems....
1. Small leak coming from Oil pan seal
2. Speedo cable leaking tranny fluid
3. Alittle white smoke on startup - Needs valve seal's?
4. Tilt steering wheel stuck - Says gear is stripped
5. Rear hatch electric motor broken - Cord holding down rear hatch
Give me an estimate on how easy it is to fix those things. He only wants 900 dollars so i'll probably buy it. Thanks again
Old Dec 9, 2005 | 09:33 PM
91Z-28's Avatar
Re: More 3rd Gen questions
I know the rear hatch can be a pain in the ***. Also it is HARD to distinguish an L98 from an LB9 visually, so be wary that it may not be what it seems.
Old Dec 9, 2005 | 09:37 PM
UtOhCop's Avatar
91,
I just watched your car video in your sig. You're one crazy ****.
I'm also not really worried about what engine it is. Just worried about the problems. Engine's coming right out anyway.
Old Dec 9, 2005 | 09:41 PM
91Z-28's Avatar
Originally Posted by UtOhCop
91,
LOL, that wasn't even me, that was right before I bought this car. 900$ is damn cheap, if you have the know-how then that might be worth your 900$. Unfortunately with cheap used cars there may also be some expensive problem lurking beneath the surface.
Old Dec 9, 2005 | 10:09 PM
Dave89IROC's Avatar
not worth it
whats the phone number?....................................
Old Dec 9, 2005 | 10:24 PM
1987IROC350's Avatar
Are you talking $900 for the convertable in the earlier post? Thats gotta be worth $5500. If not any Z is a good deal at $900. I've replaced rear hatch motors. No prob. You might be able to fix yours with a gear set. Try Hawks 3rd gen. The only hard part might be the tilt steering. Keep us posted on your motor project. Good luck.
Old Dec 9, 2005 | 10:48 PM
UtOhCop's Avatar
No this isn't for the vert. They won't come down off of there price of 9K. 900 is for an 88 Iroc
Old Dec 9, 2005 | 11:57 PM
90rocz's Avatar
You must pin point the leak first, the pan gets wet if it leaks anywhere above also. Most pan gasket were silicon rubber, try snugging the bolts first.
Again, gets loose with age, snug it first, then replace "O"ring, take your old one to the store, should match it up for a couple of bucks.
Yep, valve seals, common after years of heat. Follow instructions in a manual, takes about 3-4 hours. Get a valve-spring-compressor that mounts to the rocker stud, and use a magnetic pick-up tool to pull the locks.
Never seen that, many of them loose. They can be retightened, replacing it isn't difficult. Under the lower dash cover is to bolts holding it to the dash, a couple at the floor, and a pinch nut at the gear. And ofcourse the electrical connects.
If you SLAM it it will shut. I'd check contacts first, and wiring for voltage at the latch. There's also a relay back there. If all else fails and voltages check out, replace the small motor.
(I bought my '86 T-Top, TA with a bad tranny and no center console, bad hood/trunk lifts, bad tires, more than a couple of leaks...for $500...fixed..now I'd probably ask $5K for it.)
Old Dec 10, 2005 | 12:09 AM
UtOhCop's Avatar
Thank you 90.
Told the guy i'm going to take it. Gonna setup a pickup date tomorrow. I'm just going to tow it home.
Old Dec 10, 2005 | 07:14 AM
91-Z28-L98's Avatar
Then why do you care about the smoke on startup or the oil pan leak?
Also, I spent a lot of time trying to repair an old rear hatch motor and eventually did after spending several hours reading through wiring diagrams. After doing it myself, I would recommend just buying a new one off of ebay for like $25.
Old Dec 10, 2005 | 11:33 AM
UtOhCop's Avatar
Because i was going to drive it home. One of the reasons why i wanted to know about those 2 problems.
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Dec 21, 2014 09:47 PM
19redta96
Jul 23, 2002 12:25 PM
stars1010
Jul 15, 2002 03:51 AM
