HVAC problem
Old Dec 8, 2005 | 06:26 PM
zlightning's Avatar
HVAC problem
Ok after about being on full blast for around 10-15min my heater starts to smell. The other day I also set it to just blow out the top vents and then smoke came out of it. Anyone ever had a problem like this? Doesn't seem to be much air coming out either. If I turn it down to the 2nd highest setting it takes longer to smell bad. Any ideas? I just got hit with about a foot of snow so I won't be able to work on it right away but would like an idea of where to look. I am already going to check the blower motor.
Old Dec 8, 2005 | 06:41 PM
CamaroBoy96Z28's Avatar
Re: HVAC problem
My first inclination would be the blower. What does it smell like? Coolant, burning plastic, or something else? Any noticable difference in the blower performance between settings?
Old Dec 8, 2005 | 06:56 PM
zlightning's Avatar
Re: HVAC problem
Between high and the one right below it not really. It's hard to tell what it smells like cause I have never smelt anything like it now that I think about it.
Old Dec 8, 2005 | 07:12 PM
Re: HVAC problem
A burning smell would probably indicate the blower is burning up. Coolant has a unique smell and one I know all too well. You can pop your radiator cap off and take a whif to get a hint of coolant smell which would point to something heater core related but I'm sure you'd notice a leak if that was the case. Leaky heater core is more of a 3rd gen issue.
Old Dec 8, 2005 | 10:36 PM
Re: HVAC problem
Smoke from something electrical is as about as unique as a coolant smell. Both are different, but with coolant, you would also have moisture in the smoke (vapor).
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
ReznorZ28
Aug 27, 2002 03:53 PM
