how do I remove front spring and shock?
Old Dec 6, 2005 | 02:47 PM
dsmith's Avatar
hey guys, I'm in the middle of converting my 94 brakes to c5's. I've got it down this far, might as well change front shocks and springs while i'm at it. I have in my posession some slightly used Eibach pro's and some Koni's (less than 5k miles from a 00 camaro ss) and was wondering how hard is it to remove the shock and spring in one piece. I'll probably pay someone to compress the springs. Thanks in advance
Old Dec 6, 2005 | 04:07 PM
Re: how do I remove front spring and shock?
See the detailed spring/shock swap writeup, here:
http://members.aol.com/InjuneerZZ/HALEibch.htm
Getting the spring/shock assembly out is not all that hard.
Old Dec 6, 2005 | 04:55 PM
dsmith's Avatar
Thanks Fred, that was an excellent write up on shock/spring removal. Hope I don't ruin the ball joint
Old Dec 6, 2005 | 08:30 PM
Shempy's Avatar
Here's an alternative method with photos. I used this method on two different f-bods.
http://www.yearone.com/enthusiast/ar...ing%20swap.htm
Old Dec 6, 2005 | 09:10 PM
Greed4Speed's Avatar
also check out ls1howto.com or installuniversity.com
Old Dec 6, 2005 | 09:15 PM
OBE1 95Z28's Avatar
Harbor Freight sells a ball joint "press" for around $7. Makes separating ball joints a breeze.
Old Dec 7, 2005 | 01:31 AM
Lower's Avatar
As Fred's write up touches on, you may not have to separate the ball joints.
I know I didn't have to on my 94 Formula. Cross your fingers.
Old Dec 7, 2005 | 04:40 AM
dsmith's Avatar
thanks fellas, looks like I dont have to mess with them ball joints after all. Hey Fred, I read your article on modifying the jounce bumpers in the rear. How did those hold up after a couple months/year ? I think with the car lowered and 18x10.5 (stock zo6 rims) in the rear I might have to use your method . I'm currently driving on those rims (stock panhard bar). Had to modify the inner tire well with a BFH to make it work. Only problem now is it looks like a 4x4 on the freeway, hence the spring change. Thanks again for the tips, this is a great informative web site! Dean.
RUENUF
Mar 13, 2016 03:39 PM
siguy
Nov 27, 2014 10:07 AM
MJ_Z28
Aug 8, 2002 09:07 PM
MJ_Z28
Aug 7, 2002 07:15 PM
