noise on new brake setup
Old Nov 30, 2005 | 07:07 AM
SpeedDemon02SS's Avatar
is it normal for a new brake set up to make some noise? i am hearing a rubbing sound from the rears...much like if the rotors were slightly warped...but thats not right seing they only have 10 miles on them.
also, on the first few full stops...as soon as i come to a dead stop, there was a louder sound. almost like a bang. but that went away after a few stops. is this all normal?
Old Nov 30, 2005 | 08:32 AM
Re: noise on new brake setup
MORE UPDATE -
it is the front passanger side that is making the noise. it was making the noise before the new brakes. i just thought the old ones were warped. is it possible that there is a problem in the hub bearings?
I have notices taht when i lift the car...all the wheels rub, but not loudly. but the front passanger is really loud. almost seems as though the rotor is tilted. i have also noticed the sound gets louder when i am accelerating, or when braking. but quieter if just costing.
Old Nov 30, 2005 | 02:03 PM
ttt
more update...see below...please help...anyone...
Old Nov 30, 2005 | 02:42 PM
Greed4Speed's Avatar
Remove the wheels and make sure the rotors are flat against the hub the reinstall the wheels. I've seen the rotor get loose when installing the wheel and still not set flat once the lugs are on.
Old Nov 30, 2005 | 02:47 PM
is this a common thing? I had the same thing on my stock brake set-up. but i will try that when i get home. Is there a way i can make sure the rotors are sitting flat against the hub when installing the wheel? why would the noise get louder under acceleratoin and braking?
also, is there anyway to eliviate the rubbing on the other wheels? it is not as severe as the one.
Old Dec 2, 2005 | 08:11 AM
Ok...i took the wheel, rotor and caliper back off. inspected everything. put it all back together. The rotor is sitting flat against the hub...but it is still rubbing. I also notice a slight noise from the hub...and have a feeling there is a flattened bearing in there. can at bad set of bearings cause this problem?
Fastbird93
Apr 9, 2016 07:01 PM
May 1, 2015 01:14 PM
Fatdog2
Feb 12, 2015 12:24 PM
ddr698
Jan 9, 2015 10:05 AM
Collector Car
Jan 5, 2015 10:58 AM
