What scanner to use.
Old Nov 29, 2005 | 01:25 PM
LT1 POWR's Avatar
I have a 96 but i have a OBDII to OBDI conversion. When i get a trouble code and i drive to O reiley's to get it scanned what cable should i use, OBDI or OBDII. Also i would like to purchase my own scanner. Nothing fancy just something so i can see trouble codes. So what kind would be compatible with my car. And i have a scanmaster hooked up to my car. Will it read trouble codes when i get the OBDI computer installed.
Old Nov 29, 2005 | 03:23 PM
turbo_Z's Avatar
Re: What scanner to use.
If you have a laptop you can get freescan for free and a cable costs around $65 I believe. Or you can find those scan tools that only pull DTCs but you need to make sure it is OBD1 with a 16-pin ALDL port or sometimes called an OBD2 ALDL port.
Old Nov 29, 2005 | 04:36 PM
Mikes 1994 z28's Avatar
Yes, the scanmaster will read trouble codes for ODBI
Old Nov 29, 2005 | 10:36 PM
turbo_Z's Avatar
Exactly, sorry I should have read your entire post. Didnt see you have a scanmaster.
Old Dec 2, 2005 | 09:07 AM
Z28_95RIDE's Avatar
Can't answer anything about the scanmaster but I have a 95 which is an OBD1 with the 16 pin ALDL connector. You have a 16 pin connector too so you should use an OBDII cable.
I have an Actron CP9145 which works better than expected. It keeps data frames while driving and even gives me the 134a pressure in my A/C. Very nice unit, very easy to use. I've fixed several cars because of the Actron which would have otherwise probably gone into a shop. Even the less expensive Actron will do what you want, it just won't be compatible with other OBDI vehicles. That's one nice thing about a 95, although it was an OBDI vehicle it was equipped with the OBDII connector like your 96.
Regards
Nayr
Mar 3, 2023 08:34 PM
plattted
9
Sep 20, 2015 11:23 AM
98-LS1Z28
Sep 8, 2015 03:12 PM
z28cam1993
Jun 15, 2015 07:32 AM
