Temp gage on 93
Old Nov 26, 2005 | 06:26 PM
sprawl333's Avatar
Temp gage on 93
I have a 93 Z and the temp gage at the dash stopped working. If I replace the temp sensor with that most likely fix it? Does anyone know the simplest way to change that bad boy?
Old Nov 26, 2005 | 08:39 PM
crasher88's Avatar
Re: Temp gage on 93
First I would check to make sure the guage is working properly. Unplug the temp sensor and check the guage then bridge the two wires together with like a paper clip or something of that nature and see what happens. It should read extreamly hot on the guage. If it doesn't then you have other problems that need to be addressed. If it does then I would just replace the sensor. Should be like a 22mm wrench or if you can get a socekt on there. Just tape up the threds of the new sensor with some tefhlon(sp?) tape to make sure you won't have a leak.
93 RedBird
Nov 15, 2015 08:24 AM
1bad427ls1
Sep 23, 2015 01:12 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
