pointless to run nitto 555r on the street if...???
Old Nov 24, 2005 | 10:27 AM
djm_e22's Avatar
I have been thinking of buying some 275/40/17 nitto 555r's. But was curious if the HOPEFULLY few times on the street that I do happen to race, do I have to warm up the tires to have any kind of better traction over regular street tires, or will these still have alot better traction than a street tire even if I don't warm up the tires with a burn out. Thanks for any help.
Old Nov 24, 2005 | 11:07 AM
ABA383's Avatar
Re: pointless to run nitto 555r on the street if...???
All 3 of the major brand DRs (Nitto, BFG, M/T) need a little heat to work well, but all will work better than a regular tire on the street even without heat. I have never used the Nittos, but I know that the BFGs hook good on the street and the M/Ts hook great everywhere...and for drag racing, the 16" will hook better than the 17" because the 16" tire has more side wall...good luck...
--Alan
Old Nov 25, 2005 | 03:45 AM
hairbear's Avatar
By just driving on them they heat up enough for traction and will outdue a regular radials on the street. They will not last as long nor will they handle wet/snow roads like street tires.
Old Nov 25, 2005 | 08:02 PM
Greed4Speed's Avatar
The thing about soft tires is that they pick up a lot of debris (gravel, sand, etc). It is always beneficial to spin them a little prior to a run to clean them off.
Driving on them isn't going to keep them clean or heat them enough for optimum traction. When you first get on it you will spin just as bad as with a regular tire, but after you've spun a little they will heat up and give you traction no regular radial will.
I ran MT's on my 70 SS and am running BFG KD on my 00 SS. They are the same way.
Old Nov 25, 2005 | 08:38 PM
djm_e22's Avatar
The thing I am wondering though is since I have a 10 bolt is it likely for me to break the rear end with my 3.73 gears. Cause what if I do try to spin them but I get traction at a high enough rpm? Is there an rpm I can spin it at and know I am not going to get enough traction to break the rear end?
Old Nov 26, 2005 | 12:26 AM
hairbear's Avatar
Seems like when my cars get 7.70 or faster in the 1/8th is when the 10 bolts start popping but some people have yet to break them and have been quicker than that.
And DR's do pick up ALOT of debris
Old Nov 26, 2005 | 09:01 AM
People have broken the 10 bolt stock, and some are running 11's on the 10 bolt.
If you are spinning when moving, the chance of breakage is less than if you are at a standstill and hook.
Old Dec 1, 2005 | 01:20 PM
"White Knight"'s Avatar
you won't break a 10-bolt on 555R trust me Last time I was at the track i was sideways off the line. I didn't heat them very well. Best 60' i have run is a 1.769
ET streets are in the near future....
Old Dec 1, 2005 | 01:42 PM
Klypto's Avatar
not saying u will(i know ppl running 11s on stock 10 bolt) but i snapped axle with stock power(well a LID and gutted cats) on 245/50/16 nitto555r
just GL and hope all goes well..
cory
Louey
Pacific
Jan 25, 2015 12:22 AM
Jason Short
Jan 19, 2015 06:33 PM
cmdeshon
Dec 27, 2014 10:06 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
