Storing car for winter, what to do?
Old Nov 16, 2005 | 10:18 PM
Camarocracy's Avatar
So I'll be storing my car for winter shortly. What should I do to keep it safe for the next 3-4 months?
Old Nov 17, 2005 | 07:25 PM
Guest47904's Avatar
Guest
Re: Storing car for winter, what to do?
Since you don't know how old the fuel is, run it close to empty. (not too low to damage the fuel pump) Then refill it with from a brand name refiner. When you do, put stabilizer in the tank at the recommended rate. Be sure to drive it long enough to get the new fuel/ preservative mixture all through the system.
Change the oil. Get a solar trickle charger. You may want to fog the cylinders but that depends on the humidity in your area. Jack the car up so the tires are off the ground.
cover it and lock the door.
Old Nov 17, 2005 | 11:51 PM
Bersaglieri's Avatar
I'd start it at least every week and run it. I had no problems with mine just parking it and leaving it. I'd start mine once a month. But the opti did go from getting moisture inside from not running enough.
-Dustin-
Old Nov 19, 2005 | 11:18 AM
JoeliusZ28's Avatar
agreed, and make sure your tank is FULL. the less open space in your tank, the less condensation you can get in there.
-Dustin-
he has a 97 w/ a vented opti, so moisture in the opti shouldnt be a problem. When storing a car either dont start it AT ALL or start it weekly. both methods seem to work equally good. Just make sure if you go the starting method, you let it warm up COMPLETELY, your better off even letting it get a little hotter than normal on the temp guage than not hot enough. if you dont warm it up all the way you will just be adding to the condensation in your exhaust and oil - not good.
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
Dec 1, 2014 08:08 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
