what is the right caliper
Old Nov 15, 2005 | 08:47 PM
SpeedDemon02SS's Avatar
i mixed up my calipers. what caliper for what side of the car? should the bleed valve be on top, or on the bottom.
Old Nov 15, 2005 | 10:55 PM
gt_biker13's Avatar
Re: what is the right caliper
You seem to be confused, so ill try to answer all your questions in your other threds
Ask 5.0
on the brake pads, one of the pads has a little nub sticking off on the back. is the the inner or outer pad?
Inner pad
was i supposed to get new chatter plates (that is what the book calls them)with my brake pads? Im looking for the clips that hold the pads into the caliper guide. i lost one, and i need antoher. GM says i have to get them with the pads. anyone know where i can order them? gmpartsdirect.com?
Yes you should get new "chatter plates" when you buy new pads or calipers. I ordered new pads and calipers so i happen to have 2 sets of them, i can give you the one set if you pay for shipping.
Old Nov 16, 2005 | 01:22 AM
5.0THIS's Avatar
Originally Posted by gt_biker13
Bleed valve should be on the bottom.
You seem to be confused yourself. Bleeder valves face up towards the wheel well. This is so that any air in the system will rise to the top near the bleeder to be pushed out.
Old Nov 16, 2005 | 01:27 AM
CamaroSS30thAnn's Avatar
also the calipers wont fit mix matched i learned that when i powdercoated mine and forgot which was which
Old Nov 16, 2005 | 06:30 AM
gt_biker13's Avatar
Yeah that was just i guess, i thought if it was on the bottom then the brake fluid would drain better. Thanks for clearing that one up. Im in the process of working on the brakes and just havnt mounted them so i didnt run into that problem yet.
Old Nov 16, 2005 | 08:05 AM
thanks for the help.
also, the calipers will fit mis-matched. cause i guess wrong i mounted them with the bleeder valve on the bottom, and the brake line on top.
as for the nub...that goes on the inside, facing the front or rear of the car?
is there a place where i can get new chatter plates?
Old Nov 16, 2005 | 08:15 AM
gt_biker13's Avatar
The nub should be pointing towards the ground (thats what my dad told me). If you read my first post i offered to give you the chatter plates since i have extra, or you can buy new brake pads and you will also get them. I dont believe you can get them seperately.
Old Nov 16, 2005 | 08:23 AM
id doesnt point towards the ground...incomes parallell off of the back of the pad. soryr, i missed the part where you offered the plates. that would be awesome. how do you want me to give you the shipping? should i send you a pre-paid box?
PM me.
Old Nov 16, 2005 | 08:30 AM
also, on the back caliper...the bleeder vavle points back...not up. but that should still be above the brake line?
Old Nov 16, 2005 | 12:28 PM
hmm well mine with mine i couldnt even get the bolts to line up when i had them wrong lol
but then again im prollt justa complete tard lol
Old Nov 16, 2005 | 01:18 PM
nope...i can swich the left and right no problem. but ill just make sure the bleed valve is on top.
Old Nov 16, 2005 | 01:39 PM
Ken S's Avatar
yea, it doesn't really matter where you place the pad with that little metal piece thats designed to make noise when your pads run thin... People like putitng htem on the inner side, because its easy to visually check the outer pad, but harder to check the inner pad.
Henson071
Sep 18, 2015 04:01 PM
force10
Jul 30, 2015 04:56 PM
alphaauto
Jul 26, 2015 04:40 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
