Power Antenna lead on 1994 TA Delco CD Player?
Old Oct 28, 2002 | 08:14 AM
TA25th's Avatar
I was removing a GM Delco tape deck from my 94 Trans Am to put the factory Delco CD Player back in it, and a wire came loose from the connector that goes to my power antenna.
It appears that the tape deck is a 95+ Delco tape deck that has the auxiliary plug to hook up to a CD changer. The power antenna is a factory GM antenna, but did not come on the car from the factory.
What pin on the wiring harness does the loose lead plug in to? Does the 1994 Pontiac Delco CD head unit even support a power antenna?
Thanks,
-Shawn
Old Oct 29, 2002 | 06:09 AM
TA25th's Avatar
Unhappy
Surely someone knows the answer to this.....
Old Oct 29, 2002 | 07:22 AM
LS1 RULZ's Avatar
The best thing I can tell you is to look into the end of the plug that the wires go in and see if you can tell which pin might have been crimped.
Or you can take a look at the matching wiring harness at an install shop and match up the plugs to see where the antenna pin goes.
Old Oct 29, 2002 | 07:41 AM
TA25th's Avatar
hehe...the connector came out of the plug and is still attached to the wire. That's why I don't know where it goes. I guess I can take a voltmeter and see which pin is switched with the radio power, or take your advice and look at another plug that is still all together.
Old Oct 29, 2002 | 10:30 PM
NineSevenWS6's Avatar
I think it goes on the other end of the power side..
12vs, 12vc, immu, dim, ant Not sure tho.
Old Nov 4, 2002 | 06:09 AM
TA25th's Avatar
Any other guesses or ideas before I look at this today?
Old Nov 4, 2002 | 06:22 PM
I was wrong. I had an old harness in my room, some of the pins were wrong. I beleive its the 3rd one in. Next to the orange and yellow. Best bet it to check with a meter anyway.
Old Nov 4, 2002 | 08:19 PM
TA25th's Avatar
Cool
Cool...I didn't get a chance to look at it today. I'll let you know what I find out. Thanks..
Old Nov 6, 2002 | 09:07 PM
TA25th's Avatar
DING DING DING We have a winna!
It was the 3rd wire in beside the orange and yellow ones.
-Shawn
SLIMJIM
Jan 7, 2003 11:06 AM
BLUESMAN
Aug 26, 2002 06:07 AM
jdohman
Aug 21, 2002 07:57 AM
Red97LT1
Aug 3, 2002 07:29 PM
$hawn
Aug 3, 2002 04:59 AM
