LT1 T56 Question...
Old Nov 14, 2005 | 09:08 PM
iiibdsiil's Avatar
LT1 T56 Question...
I was wondering if the LT1 T56'd F-bodys have a switch for when you just slightly press the clutch pedal. I know they have the "Push clutch to the floor to start" switch, but wasn't sure if there is one that basically is activated whenever the clutch is even slightly depressed.
My buddy's Acura RSX has this.
If the F-bodys have this, where does the wire go? I assume it would go to the ECU. If so, what pin and connector.
Thank you in advance!
- Brett
Old Nov 14, 2005 | 09:18 PM
96speed's Avatar
Re: LT1 T56 Question...
- Brett
Sorry, but I'm not following. What does this swich do?
There is an ignition switch that closes the cicuit once you push the clutch, but it (the pedal) really only needs to be pushed down about 2". Tat is what you referred to. What is the purpose of this other swtich you speak of?
Ryan
Old Nov 14, 2005 | 09:30 PM
iiibdsiil's Avatar
I'm not sure what the purpose is, other than I would assume it tells the ECU something.
But what you are saying is the clutch only has to be depressed 2 inches in order for the car to start?
What my friends RSX has is a switch that when the clutch is depressed about 1/2 inch, it activates, tells something to do something. Then, he also has the switch that interupts/connects the ignition circuit to allow for starting, which requires the clutch to be almost to the floor.
I put a T-56 in my Impala SS, and I want to run an F-body base code on the tune, so I can get the computer control of the reverse lockout. I already have the wiring figured out for this. I was just wondering if there was more that I could/should do to make the ECU happier/be told all the information it wants to hear.
That make better sense? If it doesn't, that probably because it doesn't apply to the F-body's, which answers my question.
Old Nov 14, 2005 | 09:32 PM
rngilliland's Avatar
Yes. It is the switch to disengage the cruise control if you push the clutch. It connects to the switch on the brake pedal with a Y harness and then to the underdash wiring harness.
I don't know if it connects to the PCM. If you're doing a swap a lot of people just don't use that switch.
Old Nov 14, 2005 | 09:34 PM
iiibdsiil's Avatar
Great, thanks. That makes sense as to what it is on my friends car. I just wasn't sure if it was going to report anything back to the ECU, for say the IAC or anything else. If it was, then it would be worth hooking up to me, but it appears as though it doesn't.
Thank you.
Old Nov 15, 2005 | 07:54 PM
MR.ED's Avatar
Its easier to just wire the rev lockout to the brake pedal. Or a switch or a corvette style T handle shifter like mine.
Old Nov 16, 2005 | 10:00 AM
iiibdsiil's Avatar
Ya, I have it on a switch now. And I don't personally like the brake pedal idea. Trying to do it the factory way, just makes me feel better.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
nikolt1
Feb 27, 2015 09:10 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
