Ouch....pulling 700r4 from 91 vette..bad pressures
Old Nov 14, 2005 | 08:15 PM
dmoss69's Avatar
Check it out fellas.
COLD TRANNY FLUID PRESSURES
90PSI ...... park and neautral
75psi........ initial reverse, then bounces right back up to
90PSI....... Reverse
put it in Drive, and it hesitates for about 3 to 4 seconds, then slowly slips into gear....
D1...... 67psi
D2...... 67psi
D3...... 70psi
D4...... 83 psi with no transfer to the rear wheels.
The warmer/hotter it gets, the worse it gets.
As I rev it up, the pressure goes down.....?
HOT TRANNY FLUID PRESSURES
Reverse.......50psi
Went straight to Manual 1st, about 3 second delay, then tranny engages.
1st with brake applied............45psi
2nd with brake applied............45psi
3rd with brake applied............49 psi
4th with brake applied............65 psi no transfer
1st no brakes.........50psi
2nd no brakes.........75psi
3rd no brakes..........88psi
4th no brakes..........69 psi
All of these numbers is with a transgo shift kit, so of course the pressures should be higher than in it's stock form.
I'm ordering a pump and new converter (not needed, but it's there, so why not) tommorow.
Just info fellas, hopefully this will help someone else.
D Moss
KYWes
Jun 14, 2022 06:52 AM
canuck94z28
Aug 19, 2015 05:50 PM
karpetcm
Aug 14, 2015 03:02 PM
350350
14
Aug 11, 2015 12:03 PM
Cam's maro
Aug 11, 2015 07:45 AM
