LS2 in a '77 Camaro
Old Nov 12, 2005 | 07:19 PM
stangitr's Avatar
LS2 in a '77 Camaro
I don't know if this is the right forum, but oh well.
Anyways, I basically want to drop an LS2 in my Camaro and set it up as a pro touring/road racing car, but keep it fully smog legal. I have a few questions:
1. Has anybody done an LS2 swap into a late second gen before?
2. Is an LSx swap into a late second gen the same as in an early second gen?
3. Is an LS2 swap the same as an LS1/LS6 swap (I know they're pretty similar engines, but I'm not sure if I can use all the brackets and everything I would use for an LS1/LS6)
4. Would the Martz subframe for LS1/LS6 swaps work with an LS2 swap?
5. Which manual transmission is typically used with LS2s? (is it the same T-56 as in LS1/LS6 cars?)
6. Regarding California smog, would I be able to run true duals with dual cats legally, or would I have to use a y pipe setup? (I should probably ask the DMV about this)
Old Nov 13, 2005 | 09:27 AM
angel71rs's Avatar
Re: LS2 in a '77 Camaro
try here:
http://www.ls1tech.com/forums/search...archid=2380350
Old Nov 13, 2005 | 01:05 PM
stangitr's Avatar
i guess i finally need to cave in and join that site
Hotrods&Muscle
Feb 18, 2015 06:38 PM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
