LS1 Rear axle in an LT1?
Old Nov 9, 2005 | 10:33 PM
69gto96z's Avatar
Has anybody done this. I might have found a deal on a rear axle from an LS1 car. Does anybody know if this is possible or not?
Old Nov 9, 2005 | 11:11 PM
n2ceptor's Avatar
Re: LS1 Rear axle in an LT1?
Might try searching in the "drivetrain section".... I know there are a few differences..
Old Nov 9, 2005 | 11:39 PM
69gto96z's Avatar
I tried a search first, but the search wasn't working and kept giving me an error message.
Old Nov 10, 2005 | 09:49 AM
This should be posted in the "Drivetrain" forum. The "search" is working fine... "LS1 axle" yielded 5 hits, 2 of which are applicable to your question.
Moving to "Drivetrain"......
Old Nov 10, 2005 | 08:11 PM
Loadre's Avatar
Swap backing plates and axles and you're good to go.
Old Nov 10, 2005 | 09:42 PM
69gto96z's Avatar
Sorry Injuneer, maybe my internet is messed up or something. Everytime I would try and search, it would give me an error code. I will try again though.
Old Nov 10, 2005 | 09:45 PM
USAF Racer's Avatar
I have had one on my lt 1 for about two years. The only thing I had to do was acquire the right E brake cables. Mine was a 3 channel ABS 3:42 geared unit.
Old Nov 10, 2005 | 09:50 PM
69gto96z's Avatar
So you didn't have to change any brake lines other than the E-brake?
Old Nov 10, 2005 | 10:56 PM
USAF Racer's Avatar
Everything went right in. It tookme about two hours to do the job. The following day I drove from Sacramento Ca to Ga in three days, with no problems to date.
Old Nov 10, 2005 | 10:57 PM
69gto96z's Avatar
Awesome, thanks for the input.
Old Nov 14, 2005 | 11:43 AM
Capn Pete's Avatar
I have an LT1 rear in my LS1, and no probs. Only thing is it's easier if you can stay with the same 3-channel or 4-channel ABS setup you've already got (straight ABS or Trac-control). If you have traction control and get a non-TC diff, it's an easier conversion to make than if you get a TC diff for a car that's only 3-channel ABS.
Old Jan 23, 2006 | 12:55 PM
mike 96 ws6's Avatar
Originally Posted by Capn Pete
than if you get a non-TC diff for a car that's only 3-channel ABS.
Wait a minute. I'm lost.
Isn't the non-TCS set-up the one with the one sensor mounted in top of the gear housing and senses the reluctor ring pressed onto the carrier against the ring gear? And isn't that 3-channel?
And TCS set-up's have a sensor at each end of the axle housings which read reluctor rings cast into each axle shaft? And that's 4-channel?
If you install an axle from a TCS equipped 2000 T/A into a 97 without TCS, what all needs to be done?
Can you press a reluctor ring onto the carrier and drill the top of the gear housing to mount the non-TCS sensor?
Why?
So you went with a 3-channel axle into a 3 channel car correct? What is different about the E-brake cables?
Thanks for the help,
Mike
Old Jan 23, 2006 | 02:33 PM
Loadre's Avatar
Backing plates are different on LS1 and LT1 cars, your brakes won't bolt up.
As for the axles, some say that LS1 axles are just a weeeee bit shorter/longer.
Old Jan 23, 2006 | 04:04 PM
30696bird's Avatar
SOME SAY??? LOL I say they are, I have both. I put a LS1 rear in my car and the LS1 axles are about 1/2 inch longer. I HAD to use the LT1 axles.
Old Jan 23, 2006 | 06:02 PM
Loadre's Avatar
That's what I thought, but I didn't wanna spout off information that I was unsure of.
