Koni SA or Koni DA???
Old Nov 4, 2005 | 11:10 PM
tardy007's Avatar
It seems like I can get DA on all four corners for around $275 more than the SA. Would you guys recommend the DA or is it not worth it?
Thanks!!!
Old Nov 5, 2005 | 12:14 PM
EastLa's Avatar
Re: Koni SA or Koni DA???
I went with the SA when I had my '99. Less to mess up when adjusting. They are awesome shocks and I will buy another set when I have the cash for the '95.
Old Nov 5, 2005 | 03:39 PM
tardy007's Avatar
Yeah, did some research and I think I agree with you. Seems like I will have enough to screw up with the SA
Old Nov 5, 2005 | 11:58 PM
Eric @ DMS's Avatar
What are your intentions with the car? Typically SA's will be more than enough for most applications.
Old Nov 6, 2005 | 10:11 AM
Z28barnett's Avatar
If you want some negative camber and would like to lower the car slightly.
Then pick the Koni SA, they have two spring seat postions and you can lower the car with stock springs that way.
That is not possible with the DA.
If you plan on running lowering springs that is not as important.
Z28
JJOHNROE
Sep 8, 2015 05:39 PM
thewinner
Jun 18, 2003 12:18 PM
KTamez
Pacific
May 12, 2003 10:11 PM
i RoC U
3rd Gen / L98 Engine Tech
Sep 21, 2002 06:23 PM
KLATOO
Sep 19, 2002 09:15 PM
