dielectric grease...on more than just plugs?
Old Nov 4, 2005 | 12:58 PM
teke184's Avatar
some of you may have seen my thread about the car getting partially flooded by hurricane wilma...saltwater...
one of the o2 sensors went bad, and when i pulled the connector on the sensor one of the prongs was corroded horribly.
cleaned it off, and installed the new sensor and all is well.
MY QUESTION
if i go through all the underbody connectors and clean them, would it be a good idea to squeeze a little dielectric grease in the connectors to help prevent corrosion and maybe keep more of a watertight seal?
i'm worried about things like the connectors on the trans (skip shift and VSS etc...) and things like the connections on the rear axle and the gas tank.
this is all preventative measures...
but would it hurt??
Old Nov 4, 2005 | 02:54 PM
Dave89IROC's Avatar
Re: dielectric grease...on more than just plugs?
MY QUESTION
but would it hurt??
that is your only hope of them lasting, take them all apart, clean with electrical cleaner and grease them
Old Nov 5, 2005 | 12:49 PM
Kataklysm's Avatar
It shouldn't hurt anything to do this, I mean the grese is ok to use on electrical connections so why not? Give it a whirl on 1 thing and see how it works out.
KYWes
Jun 14, 2022 06:52 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
Xiantyl
Jul 21, 2015 05:42 AM
