can i do this?
Old Nov 3, 2005 | 07:18 AM
Foxls1's Avatar
can i do this?
1995 A4 ecm and use it in an 1995 M6
Old Nov 3, 2005 | 07:24 AM
Re: can i do this?
It's a PCM and yes you can use it with it reprogrammed for an M6.
Old Nov 3, 2005 | 08:37 AM
Foxls1's Avatar
Re: can i do this?
what will and wont work if i dont reprogram it to an M6
Old Nov 8, 2005 | 07:15 PM
Silver's Avatar
Re: can i do this?
i'm not completely sure, but i think the car will shift itself.
Old Nov 9, 2005 | 12:18 PM
MOhara6012's Avatar
Re: can i do this?
I've had an A4 PCM in my M6,
The car will start and run, though the idle speed will be different from the M6 PCM.
I didn't shift though the gears with the A4 PCM, but i was able to drive in 1st gear in my driveway (car didn't have tags at the time).
A code will be stored because the PCM does not see the A4, I don't think the SES lit up at idle/1st gear, but it probably would have if the car was driven.
It also won't go into reverse.
CAGS might prevent you from shifting into 2nd or 3rd, though I am not sure.
Old Nov 9, 2005 | 12:55 PM
Dave '97 Z28 M6's Avatar
Re: can i do this?
Fox: You need to either get an M6 PCM, or have someone like madz28 or pcmforless reflash the A4 PCM.
Old Nov 18, 2005 | 04:48 AM
davidarel's Avatar
Re: can i do this?
The M6 and A4 use differnet referrence blocks for the program and the vss output is different for both. Just reflashing with a different program won't fix it. The computer actually needs to be wiped clean and programmed with the correct VIN of a car with the proper trans.
