Clutch Package
Old Nov 1, 2005 | 11:51 AM
SpeedDemon02SS's Avatar
Clutch Package
when replacing the cluch, is it nesecary to replace the flywheel as well or can i just have it re-serfaced?
Old Nov 1, 2005 | 01:26 PM
cwaldt's Avatar
Re: Clutch Package
I'd just take it and have it resurfaced. Thats what I did on my Camaro and truck this year and I haven't had any problems.
Old Nov 1, 2005 | 01:43 PM
Re: Clutch Package
thats what i thought...but i found a good deal on a McLeod package with the clucht, flywheel, and adj MC.
Is McLeod a good clutch? for the track and normal driving?
Old Nov 1, 2005 | 02:12 PM
teke184's Avatar
Re: Clutch Package
the mcleod street twin is reveared as one of the best clutches for performance...both street and strip
but it's $$$$
Old Nov 1, 2005 | 02:20 PM
Re: Clutch Package
i know...how does the centerforce rate? alonge with the upgraded hydrolics from GM?
Old Nov 1, 2005 | 02:27 PM
SSpdDmon's Avatar
Re: Clutch Package
I had one. But, my '99 slave cylinder didn't like it. Took a dump on me at the 50K mile mark. The clutch itself held great, but I had a hard time shifting it because the slave cyl. wouldn't fully disengage the clutch at high rpms. I suspect it might have something to do with the weighted spring setup. My suggestion would be to go with Spec or Mcleod.
Old Nov 1, 2005 | 02:41 PM
Re: Clutch Package
was it the clutch that went bad, or the hydrollics?
p.s. i like ur name
Old Nov 1, 2005 | 03:58 PM
Re: Clutch Package
Has anyone heard of Textralia? good/bad?
Old Nov 1, 2005 | 04:30 PM
angel71rs's Avatar
Re: Clutch Package
It's getting very good reviews over at ls1tech.com. For about half the price, I think I'll go with the new LS7 clutch/LS2 flywheel whenever it's time to replace my factory clutch. If it's good for the new 500 hp vette, should hold in my mostly stock 98.
Old Nov 1, 2005 | 04:40 PM
Re: Clutch Package
well, the kit comes with the dual friction surface, aluminum flywheel, and upgraded hydrollics. but i am still leaning towards the mcleod...its only 100 more...and from what i have read...still the best.
Old Nov 1, 2005 | 09:36 PM
Re: Clutch Package
the street twin is still a bit on the expensive side. if i just replaced the clutch with...say a centerforce or spec, and kept my stock flywheel...would that help with the softness after track runs? or do i really need the upgraded hydrolics or the mcleod MC. (note: if upgrading hydrolics...i would definatly do the drill mod as well.)
Old Nov 1, 2005 | 11:58 PM
ManicHaze's Avatar
Re: Clutch Package
id go with a heavier flywheel than stock for launching at the drag strip, the lighter ones will rev quicker but you'll bog out of the hole. u need the increased inertia to launch more effectively. something like 28lbs is a good weight, i think the stock is 20lbs... correct me if i'm wrong here...
Old Nov 2, 2005 | 08:09 AM
Re: Clutch Package
so i should just wait and get the street twin kit with steel fly?
NewsBot
Sep 14, 2015 08:50 AM
mmf_1013
Sep 12, 2015 08:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
