turn single????
Re: turn single????
Originally Posted by Hershball
I have a 95 z28, and my left turn single is not working. Its not the light, i have checked that many times, Does anyone have any idea why this light could not be working right???
Re: turn single????
It has to be in the light somewhere becuase when you leave the turn single light on to the left the light in the cluster stays on. I then move back to the rear of the car and hit the tail light and it works, now this sounds like to me a loose wire but i took the tail light out and checked everything and it all looks good to me. Please help me out on this.
Re: turn single????
You may have a bad ground circit in your taillight socket.
you can check it with an ohm meter.
http://www.buildaracecar.com/socketfix/socket.jpg
Test between the black wire and the metal on the inside of the socket
(with the bulb out)
you should get a short or very close to 0 ohms.
if not the ground is bad and you will have to replace the socket.
Also check to make sure there is an open across the black wire and
the 2 metal strips on the inside of the socket,
and
here is the real thing
http://www.buildaracecar.com/socketfix/socket2.jpg
(with the bulb out)
and
Re: turn single????
i have a 94 and it had the same problem didnt happen all the time but same thing blinker on dash would stay on then i would get out and hit the light and it would come back on,pulled the bulb out and it was good but the connection on the inside where the bublb sit hads some dirt on it not much but enough too make the bubl work when it wanted too,
stockssn2o
May 25, 2015 08:54 AM
192cobra
Jan 26, 2015 12:12 PM
192cobra
Jan 26, 2015 12:10 PM
formula79
26
Aug 5, 2002 12:21 PM
