Turbo on carbed engine?
Old Oct 28, 2005 | 09:57 AM
streetheatz28's Avatar
Wink Turbo on carbed engine?
I am currently building a low compression vortec headed 355, My freind has a 66mm hybrid t3/t4 turbo forsale that I was considering buying. Can anyone tell me the accessories i would need to acomplish this. I know i need a blowthrew carb but how many psi of fuel would i need to run around 12 lbs of boost? I will probrobly mount the turbo sts style. And it will be in a 88 sport coupe ( v6 ) camaro.
Thanks for the info and if anyone has any other information feel free to post. Thanks!
Old Oct 28, 2005 | 10:07 PM
markinkc69z's Avatar
Re: Turbo on carbed engine?
18 psi of fuel pressure or thereabouts. Just boost reference a return regulator and you'll be fine. (reference from the hat, not the manifold)
Old Oct 29, 2005 | 08:02 PM
Chrisbequick's Avatar
Don't just rear-mount any old turbo. Rear-mounts require specifically designed exhaust housings.
-Chris
Old Oct 30, 2005 | 12:13 AM
blown3rdgen's Avatar
In my opinion, you need a fuel system that can support 20psi.
6 (standard fuel pressure for carb) + 12 (~lbs of boost) + 2 (safety factor to account for G's, line bends/friction, etc) = ~20psi
Aeromotive A1000 is the common pump used with at least -08 lines.
Matt
blowthru 383
LeftoverChinese
Jan 14, 2024 03:03 PM
bose
Jan 30, 2015 02:36 PM
cmdeshon
Dec 12, 2014 10:51 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
