Will these fit right on my car?
Old Oct 26, 2005 | 09:36 AM
FNKWICKZ-28's Avatar
Im looking at a set of Z06 wheels, there 18 by 10.5 with 295-35-18 tires, and the front are 18 by 9.5 with 275-40-18, the offset is 58 mm and the back spaceing is 7.533", will these wheels fit nice under the wheels wells of my 97 WS6, will they rub at will no modifications to be done.
thanks dave,
Old Oct 26, 2005 | 10:16 AM
Re: Will these fit right on my car?
Check your dimensions. Two wheels of different widths, with the same offset, can not have the same backspace.
For the 18x10.5" wheel with a 58mm offset, the backspace is closer to 8.0". That is the factory offset and backspace of the C5 Z06 wheel. An 8.0" BS will probably put the inside edge of the tire very close (if not into) the inside fender liner.
For the 18x9.5" wheel, a 58mm offset would produce the 7.53" backspace. But there were no factory 18x9.5's, and some of the repro 9.5's I have seen are 61mm.
Your front tires (26.7") are more than 1" larger than stock, and are larger than the back tires (26.1"). Did you want them that way? You would probably be better off with a 275/35-18 in the front.
ANDYZ28
Dec 29, 2014 09:13 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
