Sway bar bushing lube question...
Old Oct 21, 2005 | 03:46 PM
CLEAN's Avatar
What kind of lube do you use for stock rubber sway bar bushings. They squeak like mad when it's cold, and it's driving me nuts.
Old Oct 21, 2005 | 04:03 PM
Bersaglieri's Avatar
Re: Sway bar bushing lube question...
I am not sure but I bet if you went to Autozone or NAPA they'd have something. I just used what came with my Energy Suspension kit.
-Dustin-
Old Oct 21, 2005 | 06:17 PM
joe-96z1le's Avatar
Most people use a petroleum based grease but Jeg's (I think) sells a specific lubricant just for poly bushings. I hear normal petroleum products can break-down poly bushings. It should work well for rubber bushings also.
Old Oct 21, 2005 | 07:40 PM
Greed4Speed's Avatar
You'll probably find that the poly bushings will get worn from suspension movement to the point where they should be replaced before petroleum based lubes will break it down. Now, if the car is a garage queen, you may have to worry about it.
Old Oct 21, 2005 | 10:53 PM
CLEAN's Avatar
All stock suspension, '02Z28, 30k miles, garage queen . All rubber bushings as I understand it from the factory. Will find out next week!
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
force10
Jul 30, 2015 04:56 PM
SpeedJunkee
Jul 19, 2015 09:06 PM
