rebuilding 4l60e?
Old Oct 20, 2005 | 09:44 PM
snakethis69's Avatar
rebuilding 4l60e?
how hard is this exactly? are there a buncha things that need calibrated and stuff? or can i just order a rebuild kit and rebuild it?
Old Oct 21, 2005 | 07:29 AM
camaro81's Avatar
Re: rebuilding 4l60e?
Do you have any experience rebuilding transmissions?
I was told that with the 4L60E, its best to leave the rebuild to someone with years of experience. They're so complex, it would be very easy for some stuff to get overlooked. Also they require a VERY clean work area, since something as minor as rag lint can clog a spool valve.
Though if you still would like to try it, its best to go to a junkyard or somewhere else and get you some already damaged 4L60E's to take apart so you learn a little bit about them first.
Old Oct 21, 2005 | 11:14 AM
yea mine is damaged but osmoene quoted me 1300-1500 to rebuild it with stock internals
Old Oct 21, 2005 | 01:28 PM
2000GTP's Avatar
You could get a full "race" rebuild from these guys for that price..
www.cahallperformancetransmissions.com
Old Oct 21, 2005 | 04:34 PM
12SCNDZ's Avatar
The 4L60E isn't a "beginers" transmission. There are many updated, and performance parts that we use to get these things to hold up in a racing enviroment. Aside from just throwing parts in a transmission, it takes a good amountof knowledge to get one right.
Frank
Old Oct 21, 2005 | 10:39 PM
retromek's Avatar
Cool Re: rebuilding 4l60e?
Ya, Rebuid it yourself. at this point what do you have to lose? It makes me laugh when some one asks a question how to do something on a 4l60E there is either no reply or someone starts banging the CPT drum.
Then here come all the offers to rebuild it for ya. It's obviuos you can't rebuild these trannies to a parts configuration matching the power output of a V-6 wich is what alot of low price rebuilds do. And it is tricky but it can be done. It'll cost $600 plus in parts not to mention your time, If it's a whorthwhile gamble for ya...Go for it.....But if you've never done anything mechanical before forget it pay the money and have somone else do it.
Old Oct 21, 2005 | 10:49 PM
Cmr0z28's Avatar
Old Oct 21, 2005 | 10:56 PM
i think CPT has a good thing going if i can get the money. i have gotten alot of answeres back about rebuilding it. no offers to do it for me. i am gathering that it is a hard tranny to work on though. and i wont be able to build it to handle the power i will be putting out
Old Nov 15, 2005 | 06:36 PM
lefty's Avatar
has anyone(not a pro) rebuilt their own with good results
Old Nov 15, 2005 | 07:02 PM
i am getting ready to start i will tell u how it turns out.
Old Nov 16, 2005 | 04:09 PM
lefty's Avatar
i just recieved the atsg manual on it.skimmed it quickly,doesn't look like a cakewalk.
Old Nov 16, 2005 | 04:42 PM
12SCNDZ's Avatar
You also might want to remember that the ATSG manual will tell you how to rebuild it back to stock. Stock simply won't work in a performance/racing application.
No, throwing a shift kit in an otherwise stock transmission won't work, either.
Frank
Old Nov 16, 2005 | 05:31 PM
1SlowFormula's Avatar
Also, if you are going to do it yourself be very careful you note where every different size bolt from the valve body came from. The reason for this is because if you put the wrong length bolt into a hole designed for a different length one, you will clog or open a fluid passage that isn't supposed to be.
Plus there are many other little things like that to look out for.
Old Nov 16, 2005 | 08:15 PM
lefty's Avatar
is there a performance rebuild manual out?
Old Nov 16, 2005 | 11:04 PM
tfperf's Avatar
Don't forget the special tools required. Add that to your list of things to get. You'll find they aren't cheap.
