Underdrive pully
Old Oct 20, 2005 | 11:26 AM
SpeedDemon02SS's Avatar
Underdrive pully
How effective is an Underdrive pully?
What would be the better mod: underdrive pully, or new gears?
Old Oct 20, 2005 | 11:43 AM
Greed4Speed's Avatar
Re: Underdrive pully
Out of those 2, gears by far.
Old Oct 20, 2005 | 11:45 AM
Even though i am using the stock carrier? Should i just wait till i can afford a 12 bolt?
Old Oct 20, 2005 | 05:03 PM
danziger's Avatar
Gears will still be more effective...even in the 10-bolt. However, I've had my ASP pulley on for 4 years with no problems and it was probably worth the 8-10rwhp advertised.
Old Oct 21, 2005 | 09:58 AM
teke184's Avatar
most gains....gears
easier to install....pulley
you probably won't feel the gains from the pulley, you'll definaately fell the gains from the gears, but you'll also need to get it programed to change the shift points or speedo...so the cost is alot more
Old Oct 22, 2005 | 10:45 PM
arnoli's Avatar
Good input fellow, my ASP pulley is on the way, it will complet the job.
Arnoli
Old Oct 22, 2005 | 10:51 PM
ULTIMTEORANGESS's Avatar
if you can its a good investment.i wish i had done this instead of fixing my 10 bolt over and over.
Old Oct 23, 2005 | 12:13 AM
i think ill just do both gears and a pully...
i cant afford the 12 bolt yet, but ill just start saving now. at least ill have an extra set of gears in the garage
Old Oct 23, 2005 | 05:34 PM
00Z28SS's Avatar
I did both and vote for gears by far. A little more money and time involved though.
Old Oct 23, 2005 | 09:39 PM
GoFast908Z's Avatar
Member
do the underdrive pulleys give less power to the AC and stereo? I want one but i don't want my AC to suffer.
Old Oct 23, 2005 | 10:19 PM
my AC works fine and i have an a4.
Old Oct 23, 2005 | 10:23 PM
GoFast908Z's Avatar
Member
what about the stereo?
Old Oct 23, 2005 | 10:38 PM
only thing that happens is when everything is on.AC,rear def. ect and im stopped the needle will go into the red zone but once im moving it goes back into the normal range.
unless you have a custom system you shouldnt have any stereo problems.you could always have your idle raised.i had mine raised slightly.
Old Oct 23, 2005 | 10:50 PM
GoFast908Z's Avatar
Member
cuz i do have a good sized stereo, and an Optima Yellow Top. I had the idle speed raised for my stall convertor, but don't want it too high.
Old Oct 27, 2005 | 11:02 AM
00Z28SS's Avatar
I was told to get the alternator pulley if you are running a system, but it's not necessary if you are not. You should be fine if you get both.
