Right rear of car sits lower than left rear
Old Oct 18, 2005 | 07:47 PM
EviLBoX's Avatar
I have 75K on my car with the stock suspension. Today I noticed that the rear right of my car sits about 1" lower than the rear left, what causes this? Worn out shocks? Springs? I'm guessing the only thing to fix this is new shocks/springs? Thanks for the help.
Old Oct 18, 2005 | 07:52 PM
Silvershark's Avatar
Re: Right rear of car sits lower than left rear
I have the same problem, but mine is the drivers side... I think my spring is cracked.
Old Oct 19, 2005 | 07:57 AM
Greed4Speed's Avatar
Springs support the car, not the shocks.
Even with new springs & shocks you may still have this.
Old Oct 19, 2005 | 03:01 PM
95 WHITE TRANS's Avatar
I have changed springs and shocks,still an inch lower on passenger side.Checked out the frame and diff at gm dealer everything is fine.I guess it's just the way some of them are made.
Old Oct 19, 2005 | 06:13 PM
2000GTP's Avatar
Guess its time to get an airbag.
Old Oct 19, 2005 | 07:01 PM
Brez's Avatar
Just a shot but do you have the spare tire in the rear?
Old Oct 19, 2005 | 07:12 PM
NOT TRYING TO STEAL YOUR POST EVILBOX
Yes i do never thought of that.Do you.
Old Oct 19, 2005 | 08:54 PM
USAF Racer's Avatar
My 94 does the same thing. I even took out the spare (replaced it with fix a flat), replaced the springs and shocks, adjustable panhard rod, still did not correct the problem. If it is the springmount is there a fix? I see alot of F bodies like this.
Old Oct 22, 2005 | 01:00 AM
Z95m6's Avatar
mine does the same thing. I put in lowering springs and i had to end up getting a aluminum spacer from a local suspension shop to put under one of my coil springs.
Old Oct 22, 2005 | 09:11 AM
n2ceptor's Avatar
I remeber a thread about 2 years ago on this and the consensus was usually right side was about 1/4 to 1 inch lower than the left.... Might be from body flex?????
Old Oct 24, 2005 | 06:49 PM
b55baron's Avatar
My 2000 did the same thing. It was off about 5/8". I've got the weight jackers from Ground Control, so I ran the rr up 3/8" and dropped the lr 1/8" to even it out. I left the left side a little high so when I put my fat **** in the seat, it evens out.
Old Oct 27, 2005 | 09:06 PM
touch109's Avatar
had my right side lower by 3/8 of an inch took it to the dealer and replaced the rear springs... everything was evened out..
02 SS A4 48Kmiles
bfmv13trivium
Jan 14, 2015 09:57 AM
ModdedNerd
Jan 1, 2015 10:56 AM
ModdedNerd
Dec 25, 2014 05:51 PM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
