Question on Intake Manifold
Old Oct 17, 2005 | 11:30 AM
RallyRed701/2's Avatar
I bought my 70 camaro not knowing really anything about it. Im trying to figure out just what my motor has on it. I took off the carb to rebuild it, and in doing so i took a look at the intake manifold's serial/model number. I looked all over the net, and im yet to find anything about this intake manifold. It is a gm intake, model # 14044886. If anyone can get any info on this intake please let me know... thanks in advance.
Old Oct 17, 2005 | 06:37 PM
master of a-bodies's Avatar
Re: Question on Intake Manifold
www.mortec.com
Old Oct 17, 2005 | 07:14 PM
StrokinIt383's Avatar
look at the casting number on the rear of the block if possible. That will tell you alot.
Old Oct 19, 2005 | 08:25 AM
Originally Posted by master of a-bodies
its an awsome site, but it wont tell me anything about my intake manifold.
Old Oct 26, 2005 | 07:23 AM
billscamaros's Avatar
are you sure about that number? i tried looking that up in a couple of books, and couldn't find any intake manifold numbers that were even close.
is this a four barrel or two barrel manifold??
thanks
bill
Old Oct 26, 2005 | 11:29 AM
its a 4 barrel manifold for certain, and im like 90 percent about the number (it was kinda dark at the time i checked). But ill check again and let you know. Also its a dual plane manifold (although im not sure if gm made single or not).
Old Oct 26, 2005 | 07:42 PM
redblur's Avatar
In general, GM doesn't make high performance intakes for their stock engines. The only exceptions being the late 60's hi-po Z/28 intakes (which the casting numbers are well known not to mention rare) and their crate engines which also have easily identifiable casting numbers. If yours isn't ringing any bells then I would safely assume that it's just a run of the mill factory q-jet 4bbl intake with the advantage of being aluminum, if it is. That being assumed, then factory GM intakes were basically edelbrock performer intakes, good from idle-5000rpm, with emphasis on building low speed torque by utilizing relatively small runners. It will be a fine intake for a street/mild perf 350 engine up to probably 350-370HP and around 400ft/lbs. You need not spend good money on a new intake unless you want to. Free advice.
Old Oct 28, 2005 | 11:38 AM
Hey, thanks a bunch for the words of wisdom... i always take advice if its free.
Old Nov 12, 2005 | 02:03 PM
arocars's Avatar
I put your manifold number into Google and came up with a guy on a corvette website asking the same question, but there was no direct link to the question or the answer (it would require searching the site). Give it a shot.
Check the manifold and see if there is a 'snowflake' cast into it. If there is, its special and worth some bucks.
Noer
Feb 28, 2015 11:29 AM
CARiD
Jan 27, 2015 06:27 AM
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
