rear sway bar, not lining up
Old Sep 15, 2005 | 02:20 PM
LEATHAL Z's Avatar
I installed a new moser 12 bolt and bmr control arms, now i am having troubles mounting up the new sway bar. i don't think the hellwig corp. would think someone would be installing there product on a 12 bolt but it is not lining up right. anyone with any advice or info would greatly be apprecieated.
Jessie
Old Sep 15, 2005 | 05:09 PM
93ZM6Tally's Avatar
Re: rear sway bar, not lining up
If you're having the trouble that I think you are using the stock u-bolts and brackets they won't work. I ended up buying a set of brackets made for the Moser axle size, 3", and then had them welded up. The stock sway can then just be bolted up without using the u-bolt at all.
Old Sep 16, 2005 | 11:12 AM
LEATHAL Z's Avatar
i have the bigger u bolts, when i ordered the new SB i forgot to tell them it was going on a moser rear end.
Old Sep 17, 2005 | 06:28 AM
ABA383's Avatar
Check out Spohn Performance. They make specific sway bar mounts for 12 bolts/9" rears. It properly locates the sway bar and should make mounting it very easy...They go for $75.....www.spohn.net
--Alan
Old Sep 17, 2005 | 06:26 PM
93ZM6Tally's Avatar
--Alan
That's what I'm using and they line up perfect. I used these same brackets first for the stock sway and now for the Spohn Drag Bar.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
8T8IROC
Mar 26, 2015 09:02 PM
thenewkid
Nov 27, 2014 09:41 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
