is the 700r4 from a 88 camaro the same as the one from a 93 z28?
Old Sep 15, 2005 | 11:33 AM
nonojoe66's Avatar
ok my transmitions on its way out, but i have a 88 camaro with a bad 305 but a good transmiton, since my 93 has a 4l60 and not the 4l60e is it the same as the one in the 88? and will it just bolt rite up? im not 100% sure on the condition of the one in the 88 so would i just b better off having the one in the 93 rebuilt?
Old Sep 16, 2005 | 06:31 PM
M93Z's Avatar
Re: is the 700r4 from a 88 camaro the same as the one from a 93 z28?
The case is the same but the electrical connector is different, 93 has a round 5 pin & the 88 has a 4 pin.
Old Sep 17, 2005 | 06:03 AM
Pro Built Automatics's Avatar
Most of the Chevy's have the 4 pin, the Pontiacs have the 5 pin. The 1993 is a better transmission to start with, more upgrades.
Old Sep 17, 2005 | 08:33 AM
beast85's Avatar
stick with the 4L60 the 700r4 won,t shift into overdrive at full throttle, if you upgrade your car any it can be a major killing factor for any times, or any rice eating on the streets. look around for a cheap rebuild place, see if you can find someone who will take the tranny out of car. it can knock off a couple hundred bucks usually. like i said look around first, ask your local machine shops who they deal with, they usually give reputable dealers. john
NewsBot
Dec 28, 2014 06:20 PM
Cam's maro
Dec 28, 2014 09:30 AM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
Jul 4, 2005 05:00 PM
