washer fluid?
Old Sep 15, 2005 | 07:55 AM
flusz28's Avatar
washer fluid?
my tuner said that they have used straight washer fluid to cool a blown cobra or mustang GT. forget which one he said, either way anyone else here of that? i know alot of guys with fast cars that have been tuned by him and had work done so they are a great company out of Stow,Ohio. i'm running alky/water 50/50 right now.
Old Sep 15, 2005 | 09:26 AM
rskrause's Avatar
Moderator
Re: washer fluid?
Windshield washer fluids are methanol/water mixtures, usually with some colorant. The percentage of methanol varies between ~25-50%. It can be used as an injection fluid in a pinch, but I prefer to be sure what I am using and mix up my own 1/1 mixture.
Rich
Old Sep 15, 2005 | 09:39 AM
Flip94ta's Avatar
Re: washer fluid?
Whoa nelly, thats not the best idea unless done right, reason being I used to sell the stuff and some of it sits in the back for 12 months waiting for next season. If you do use it buy a name brand like prestone and get it at a high volume place like target or walmart. I would see some stuff settled in the bottle of the bottles also. Our store stuff would freeze at 25-30*, which shows it was mostly water.
Old Sep 15, 2005 | 10:03 AM
mongse_1's Avatar
Re: washer fluid?
Concentrate is where it's at.
Old Sep 15, 2005 | 10:52 AM
Flip94ta's Avatar
Re: washer fluid?
nice, but does that stuff cost $1.50 a gallon??
Old Sep 15, 2005 | 10:56 AM
flusz28's Avatar
Re: washer fluid?
the meth i get is from home depo, in the paint removal section. forget the name and how much. but it is some strong stuff.
Old Sep 15, 2005 | 12:27 PM
Lisa33's Avatar
Re: washer fluid?
Washer fluid here in sweden contains 35%etanol 15% isopropanol and 50% water, works fine for cooling, Only 10degrees raise under a 1/4 run togheter widh the FM OBX IC. (17psi Boost)
Old Sep 15, 2005 | 01:35 PM
rskrause's Avatar
Moderator
Re: washer fluid?
Locally we buy methanol by the drum in the summer for use in the race cras. But in the winter we get 5 gallon pails. Current price is ~3.50/g. So, a 5 gal. pail is ~$20. Mixed 1:1 with water this makes 10 gal. of injection fluid, which lasts a LONG time. The price per gallon mixed 1:1 is therefore ~$2, about the same as washer fluid and known composition.
Use washer fluid only in a pinch, IMHO.
Rich
Old Sep 15, 2005 | 01:48 PM
Flip94ta's Avatar
Re: washer fluid?
I havn't really checked injection out much, how much do you use in a 1/4 run?
Old Sep 15, 2005 | 05:17 PM
97WS6SCharged's Avatar
Re: washer fluid?
Very very little. Maybe a tablespoon or two. 90 PSI through a nitrous nozzle.
Old Sep 15, 2005 | 07:16 PM
mw's Avatar
mw
Re: washer fluid?
What size intercooler is that?
Old Sep 15, 2005 | 08:01 PM
Lisa33's Avatar
Re: washer fluid?
24*12*4"
About how much water/alky to inject, I have an 10 gallon/houre nozzle so on a 10sec trip + burnout it is aprox 0,15 qt.
ake
Old Sep 15, 2005 | 09:03 PM
flusz28's Avatar
Re: washer fluid?
i think i will stick with what i have been using. washer fluid makes me kinda uneasy with the thought of using it.
Old Sep 16, 2005 | 04:41 PM
ss#1230's Avatar
Re: washer fluid?
this is from the snow performance FAQ page......
8. Can I use windshield washer fluid?
Although most contain some glycol and detergent, most windshield washer fluids are up to 50% alcohol (methanol, ethanol, isopropanol) and make an excellent Boost CoolerŽ. Try to find one that indicates "contains methanol".
heres another thought. i hear of using methanol like you use from home depot in the fuel tank to help with smog tests. are you getting any cooling benifit from putting it directly into the tank like this?????
jeremy
Old Sep 16, 2005 | 04:50 PM
speedmiser's Avatar
Re: washer fluid?
I used the cheap 99 cent blue stuff. Approx 10.2:1, 383, with approx 14psi peak, with the progressive alkycontrol kit. Worked great in 100deg temps last summer. My timing was not very aggressive though.
