Ran on my tire with no air!!
Old Sep 13, 2005 | 10:33 AM
Yoder's Avatar
Unhappy Ran on my tire with no air!!
Hey guys,
I got to work this morning and realized I ran about 12 miles on my tire and it was pretty much completely flat the entire way! Big screw stuck in it.
I run 275/40/17 Nitto 555s and the sidewall was pretty hot when I got to work. How do I know if I ruined my tire? Should I just drop $165 and get a new one or is it salvageable? Will I have to look inside to know whether it really damaged it or not?
Old Sep 13, 2005 | 10:38 AM
Rice Killer87's Avatar
Re: Ran on my tire with no air!!
All I would do is just put air in it and see what happends.
Ive run tires completely flat about 1/2 mile on this Kia Sephia I have thats a field car me and my buddies drive through the woods and the tires always come right back up w/ air.
Im surprised your rim isnt screwed up...how fast did you drive to work?
Good luck man
Old Sep 13, 2005 | 10:49 AM
Z28SORR's Avatar
You are probably not going to be able to tell by looking. And it reallly depends on how hot and for how long it was hot. What usually happpens is the rubber starts to separate from the fabric belts internally. If this was my dailly driver, I would take a chance. IF, there were no obvious signs of problems.
However if your going to worry about this every time you drive, you may as well shell out for a new tire.
Old Sep 13, 2005 | 12:16 PM
Zack's Avatar
i would not reinflate it. chances are you got run flat damage inside. when it gets dismounted, youll see lots of tire shavings inside. Or just look at the sidewall...if you see a 'groove' shaved into the sidewall, called a heat ring, tire = no good. Where did ya get the tires? if they were fromt discount tire, road hazard will cover it
Old Sep 13, 2005 | 01:49 PM
crazypurgatory's Avatar
Lightbulb Re: Ran on my tire with no air!!
I agree with Zack.
I use to work at a tire shop and I saw a lot of tires like yours come in.
You just don't know anything till you dismount the tire and see what the inside looks like.
I have seen tires that had a line on the outside but the inside was fine because the tire didnot get that much heat into it.
Check it first a coupple of bucks is not worth maybe getting into an accident.
Chris G.
Old Sep 13, 2005 | 01:55 PM
Yoder's Avatar
Thanks guys, I agree. I called the tire store in the area that carries Nittos and they said the same thing. We'll look inside it and see how it looks and go from there.
Old Sep 13, 2005 | 02:30 PM
Blue89Bird's Avatar
am I the only one who wants to know how you drove with no air in the tire and didn't notice it?
Last time I got a flat, I had a THUMP THUMP THUMP WHAP WHAP WHAP as soon as it lost air.
Old Sep 13, 2005 | 03:20 PM
Yoder's Avatar
I do a lot of drugs...
No, really it didn't make a sound. I did suspect something because it was taking bumps hard...
Old Sep 13, 2005 | 03:22 PM
I guess it would all depend on the tire.
Every tire has a different feel to it even if you can't feel it other people can.
It all depenes on how hard the side wall is.
He is runing a 40 series so thats got a pretty hard side wall.
Maybe the Nitto 555s have a harder side wall then others.
Chris G.
Old Sep 13, 2005 | 04:36 PM
Yoder's Avatar
Yeah, and it was the rear tire. I think it would be much more noticeable on the front. I had that happen one time (blew while driving) and it was obvious.
Old Sep 13, 2005 | 07:38 PM
jchevy's Avatar
Hopefully you didnt burn up your posi driving on the flat tire.
Old Sep 13, 2005 | 09:28 PM
Yoder's Avatar
Really? How so? On the way home I was thinking that the spare must have to spin faster than than the other wheel due to a smaller diameter. Is that what you're thinking?
If so then the spare would burn up the posi too...right?
Old Sep 13, 2005 | 09:58 PM
Blue89Bird's Avatar
yes, if used on the rear. You're supposed to put a "good" wheel on the rear, and the donut on the front.
Old Sep 14, 2005 | 03:40 PM
Ken S's Avatar
I did that before.. I completely loss air while it was parked at work.. I left, jumped in pulled out. everything seemed okay, just putting around the lot, but the first turn out of the lot, it definantly did not feel right.. At the light, I even got out to run around my car,and sure enough, the passanger rear tire (always seem to be unlucky with that tire) was just about completely flat.
I limped around for like a few more blocks, then filled it with air, and then got went to tire shop. They said it was fine and patched it up.. The tires were worn anyways, so I used the excuse to get new ones.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
95chwagon
Jan 13, 2015 09:19 PM
